Date/Time: Mon, 29 Apr 2024 05:36:08 +0000
Charting Reply Sim Fills
View Count: 924
[2014-10-13 17:03:09] |
User56866 - Posts: 28 |
Hi Is is possible to display on the chart the Simulated fills which happened during a chart replay? And if so, is it possible to select from which Sim account these are from? Eg. I traded a chart in Replay mode using the Sim2 Account and I want to plot these fills. Ben |
[2014-10-13 21:38:26] |
vegasfoster - Posts: 444 |
In the upper left hand corner of the chart screen where it says "Sim Fills", click on that part of the text and change to "Replay/Backtest". Then on the menu, Trade>>Show Order Fills and then Trade>>Attach Trade Window To Chart. Once the trade window appears, select the sim account you want to see from the drop down box on the main tab.
[2014-10-13 23:48:53] |
Where can I find a reference as to what the different colours mean? (I assume they represent limits, stops etc)
[2014-10-15 00:27:41] |
For this you need to do the following: Enable Trade >> Trade Simulation Mode On. Enable Trade>>Show Order Fills . Set the Trade Account: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#SelectingTradeAccount Set the Simulation Fills Source to Replay: https://www.sierrachart.com/index.php?page=doc/doc_TradeMenu.html#SimulationFillsSource To keep the fills after a restart you need to enable Global Settings >> General Trade Settings >> Save Replay/Back Test Trade Activity. Here is the documentation for Order Fills: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#DisplayingOrderFills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-15 00:30:36
