Date/Time: Wed, 15 May 2024 11:06:24 +0000
Wrong Dom Graph on Chart Inside Bid/Ask volumes
View Count: 1134
[2014-10-13 14:24:45] |
MonteCarlo64 - Posts: 23 |
http://www.sierrachart.com/image.php?l=1413209685997.png Below is the correct Chart DOM immediately after connecting to OEC data feed. Within 1-2 seconds it changes to the above wrong DOM and stays wrong! http://www.sierrachart.com/image.php?l=1413210005158.png Version 1199 |
[2014-10-13 16:29:14] |
It is not incorrect. What you are seeing is the full market depth that the DOM Graph will display. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-13 18:12:43] |
For years I had the display of the inside Bid/Ask volume which is all that I want, I do not want the meaningless (to me) cumulative Bid/Ask volume for some number of steps of the price ladder. This new version changed this display from the prior version and I do not know why or the justification for it. Please put it back the way it was and show only the inside Bid/Ask volume or provide me with the selection option.
[2014-10-13 19:27:03] |
Nothing has changed with this at all. This is for certain. The DOM Graph by default displays all market depth levels. There is no option for what you want with the DOM Graph and never has been. You might be interested in Chart >>Show Bid and Ask Lines instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
