Date/Time: Wed, 25 Nov 2026 16:03:23 +0000
Moving Average Difference
View Count: 467
| [2025-10-02 13:43:58] |
| User847587 - Posts: 23 |
Please help me build a difference indicator between Open and Last, plotted as histogram. The Moving Average Difference doesn't do that. Thank you. Brian B. |
| [2025-10-02 17:24:35] |
Use the "Study Subgraphs Subtract/Difference" study to do this. Set the study references to be the Open and Close and set the Subgraph Draw Style to be "Bar". Refer to the following: Study Subgraphs Subtract/Difference Chart Studies: Bar (ACSIL: DRAWSTYLE_BAR) You may want to increase the "Width" of the bars. Refer to the following: Chart Studies: Subgraphs Tab >> Line Width And you may want to set the scaling for that study to be "Automatic - Zero Centered". Refer to the following: Chart Scale and Scale Adjusting: Automatic Zero Centered (Scale Range) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
