Date/Time: Wed, 25 Nov 2026 16:03:05 +0000
ritardo dei dati di 10 minuti
View Count: 476
| [2025-10-02 10:00:32] |
| User179408 - Posts: 1 |
buongiorno, sto notando che ho un ritardo dei dati su sp500 e altri indici , ho appena acquistato denali ho sbagliato qualcosa?
| [2025-10-02 16:31:56] |
From Google Translate: good morning, I'm noticing that I have a delay in the data on sp500 and other indexes, I just purchased denali, did I do something wrong?
Everything on your account looks good, so you should be getting real-time data for products traded on the CME Group. If you are still having a problem with the CME Group data, then get us your Message Log by following these instructions: Follow the instructions here to clear the Message Log:
Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-10-02 16:32:12
