Date/Time: Wed, 25 Nov 2026 16:03:18 +0000
option
View Count: 524
| [2025-09-30 06:48:52] |
| User914407 - Posts: 65 |
Bonjour, Quelles options dois je prendre chez SC pour trader le DAX, le BUND, le SP et le NQ (j'ai déjà un compte chez STAGE 5) ? Merci |
| [2025-09-30 14:28:48] |
From Google Translate: Those options do you want to take on the SC for traders on the DAX, the BUND, the SP and the NQ (do you want to know about STAGE 5)?
We do not understand what the question is here. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-30 14:41:35] |
Je suis chez STAGE 5 et je voudrais trader le DAX, le BUND, le SP et le NQ. Que faut il prendre comme abonnement chez vous ?
| [2025-09-30 15:24:06] |
From Google Translate: Come to STAGE 5 and you will want to trader the DAX, the BUND, the SP and the NQ. Why should you take the subscription you want?
We are still not quite understanding what exactly the question is. What we can gather is that you are using Stage 5 as your broker and you want to trade both EUREX and The CME Group. It looks like you already have two installations of Sierra Chart, one that is used to connect to Teton Order Routing and another that connects to CQG. This is one setup that will work for this. The only thing you are missing then is the EUREX data. To setup the data for EUREX from our Denali Exchange Data Feed, follow these instructions: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-30 16:20:48] |
Quand vous dites : "Il semble que vous possédiez déjà deux installations de Sierra Chart : l'une pour vous connecter à Teton Order Routing et l'autre pour CQG" => cela veut dire que j'aurais 2 comptes avec 2 id et 2 mot de passes ?
| [2025-09-30 17:46:47] |
From Google Translate: When you say: "It seems that you already have two installations of Sierra Chart: one to connect to Teton Order Routing and the other for CQG" => does that mean that I would have 2 accounts with 2 IDs and 2 passwords?
When we look at our servers, we see that you have 2 installations of Sierra Chart running. One is connected to Teton and the other to CQG. Is this the case, or are we not seeing something correctly? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-30 17:51:02] |
Honnetement je n'en sais rien car j'ai du mal à maîtriser la plateforme. Comment puis je voir cela ? |
| [2025-09-30 18:28:08] |
From Google Translate: Honestly, I don't know because I'm having trouble mastering the platform.
How can I see this? We can not say. It appears that you have 2 installations on the same computer. That is all that we can see. How it is setup on your computer is decided by you, and it is not something we would know anything about. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-01 06:52:20] |
Merci pour ce retour. Où puis je voir cela sur mon pc ? |
| [2025-10-01 14:53:11] |
From Google Translate: Goods for return.
Now what's hidden on my PC? We do not understand what you are trying to ask. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-01 15:30:27] |
the translator translates poorly. My question was where I see these two installations on my PC. |
| [2025-10-01 17:30:58] |
We do not know where these are located. We can just see that there have been two different instances started from the same computer.
| [2025-10-01 17:40:52] |
ok Can you tell me what is the advantage of having 2 Sierra configurations (one for EUREX and one for CME) rather than just one. I understand that in the latter case it would simply be necessary to modify the settings in "Data/Trade Service Setting"? Is this correct or do I need to make other settings |
| [2025-10-01 19:43:44] |
It all depends on how you are setup with your broker. From previous, it sounds like you are setup with two different trading accounts - one for EUREX and one for the CME Group. If this is the case, then you will want to have two different installations in order to be able to trade each of those accounts at the same time. Otherwise, you would end up switching the "Data/Trade Service Settings" between the two accounts. This is not a problem, if you do not mind doing it. Just keep in mind that if you have an open trade with one account and you change the settings, you will not have any visibility into that open trade. If, on the other hand, you have one account with your broker in which you can trade both The CME Group and EUREX, then you just need the one installation of Sierra Chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
