Date/Time: Tue, 03 Nov 2026 17:43:06 +0000
Using SC data on 3 systems - data feed confusion
View Count: 492
[2025-09-30 02:11:15]
mattvk - Posts: 37
My setup:
- 1 home computer running an instance of SC
- 2 VM Windows, each running instances running SC
- Number of Systems currently set to 2 (Denali Exchange Data Feed: Connections)
My Goals:
- Run 2 of the instances for live trading using separate accounts. Both data/trade service settings as "Teton CME Routing [trading]". One AMP and the other Stage5 - NEED live data for these.
- Run 1 instance for backtesting and strategy development, Data / trade service set as "SC Data" Data can be delayed since it's just for testing.
Problems:
- Not getting delayed data (or real time) on the "SC Data" machine for testing
- Getting a message in the trade service log of the AMP account: "MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDefferenntDevices = 3"
Open Question:
- What is the proper way to set up my needs (2 machines for live trading, 1 for backtesting)?
- Is there a way to get 3 (or 4) systems?
[2025-09-30 14:24:06]
Sierra_Chart Engineering - Posts: 25362
In the instance of Sierra Chart where you want to receive Delayed Data follow these instructions:
Sierra Chart Teton Futures Order Routing: Using Delayed Market Data
Your service package does allow Sierra Chart to be used on 3 systems maximum, but on the third system you can only get delayed data for the exchanges, where there is a cost for real-time data.
Date Time Of Last Edit: 2025-09-30 14:24:27
[2025-09-30 14:46:14]
mattvk - Posts: 37
Ok thanks - how can I purchase another data feed on my same account so I can have more concurrent systems? Do I need a whole different SC account or can I add additional real-time feeds to my current account?
[2025-09-30 15:26:42]
John - SC Support - Posts: 48408
The exchanges only allow for 2 computers to be connected to the data feed at the same time. Therefore, if you want to get real-time data to more than 2 systems, you would need a completely separate Sierra Chart account that would allow for 2 connections of its own.
