Date/Time: Thu, 16 May 2024 09:53:41 +0000
Last bar of historical chart not showing
View Count: 874
[2014-10-13 02:59:36] |
joshtrader - Posts: 442 |
I have created my own data for a historical chart and it shows up correctly except that the very last day does not load (for example, my last data is for 2014/10/10 and the last one to show is 2014/10/09). When I remove the last day, then the NEW last day does not show (for example, 2014/10/09 normally shows up, but when I remove 2014/10/10 and 2014/10/09 becomes the last day, then it does not show up). I have attached the file for your review... what could be going on here?? Date Time Of Last Edit: 2014-10-13 03:02:25
Private File |
[2014-10-13 03:07:35] |
Make sure there is a new line character after the last line in the file.
[2014-10-13 03:13:53] |
Problem resolved and can close the ticket, thanks
