Date/Time: Wed, 25 Nov 2026 21:06:04 +0000
IBKR TWS API 10.40 changes
View Count: 1309
| [2025-09-27 17:43:39] |
| User512353 - Posts: 198 |
For version 10.40 of the TWS API, IBKR writes in the release notes: "Beginning with Trader Workstation and IB Gateway 10.40, the Global Configuration -> API -> Setting will provide a new setting, "Maintain and resubmit orders when connection is restored." This setting will automatically maintain or resubmit orders on the platform after a network disconnect or following the auto-restart behavior." link: https://ibkrguides.com/releasenotes/api.htm Can you please comment if this setting has any implications on the use of the API with SierraChart? |
| [2025-09-28 14:32:29] |
| Sierra_Chart Engineering - Posts: 25483 |
We do not see why that setting would cause any issues when Sierra Chart is used with TWS: Can you please comment if this setting has any implications on the use of the API with SierraChart? Also we have no understanding about that option at all or what exactly it is doing even though it is expressing something. It makes completely no sense to us. Just sounds like more Interactive Brokers nonsense to us. What on earth does that mean. The server is always going to be maintaining, orders whether the connection is lost or not. What is the purpose of such a setting. It would seem meaningless to us. Does it mean it is going to resubmit an order, if it did not get submitted because subsequently the connection was determined to be lost after order submission, but before the order was accepted. We think that is a high risk option to use. And that is a very uncommon scenario. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-09-28 14:33:06
| [2025-11-15 23:18:52] |
I received the following answer from IBKR about what this new API option means: "The feature refers to orders that are getting queued in TWS/IB Gateway, for example when submitted in a large batch. When the setting is enabled, TWS/IB Gateway will not clear the queue upon loosing connection to IBKR server, auto-restart or midnight reset. The orders will be reverted to PreSubmitted state once the connection has been re-established." Do you see any implications for the API usage by SC in the explained behavior, especially that "orders will be reverted to PreSubmitted state"? |
| [2025-11-16 18:56:55] |
No, we do not see any issue with this: Do you see any implications for the API usage by SC in the explained behavior, especially that "orders will be reverted to PreSubmitted state"?
No program using the TWS API should have any issues with this. And Sierra Chart also never resubmits an order. Resubmission of an order for whatever reason, always has to be manually done by the user. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-11-16 19:00:32
