Date/Time: Wed, 25 Nov 2026 16:03:21 +0000
Numbers Bars Calculated Values
View Count: 670
[2025-09-25 13:02:00]
juicebro - Posts: 119
Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions
Ask Volume & Bid Volume Total (AskV + BidV): This is the total of the Ask Volume and Bid Volume for the entire Numbers Bar.
Total Volume (Total Vol): This is the total volume of the trades for the Numbers Bar.
Are these 2 always identical? I see no difference, and by description they sound identical.
[2025-09-25 14:20:52]
Functionally they should be the same, but it is possible with some data feeds that these would be different, as they may not mark trades properly as Ask or Bid.
If you are getting your data from our Denali Exchange Data Feed, then these will be the same.
