Date/Time: Wed, 25 Nov 2026 16:03:22 +0000
answer
View Count: 433
| [2025-09-24 13:56:54] |
| User282547 - Posts: 17 |
Hi, How can I add a button that, when I click it, automatically scrolls the chart all the way to the right (to the current day)? Right now, when I’m reviewing previous days, I have to manually scroll step by step to reach the live/current price, and it takes a long time. Also, how can I set an alert when the price **touches** a specific line, and another alert when it **crosses** that line? Thanks! |
| [2025-09-24 15:43:53] |
There is an option for "Chart >> Goto End of Chart" that has a keyboard shortcut set to the "End" key by default. If you want to change the keyboard shortcut for this, then refer to the following: Keyboard Shortcuts for Menu Commands: Keyboard Shortcuts for Menu Commands Also, how can I set an alert when the price **touches** a specific line, and another alert when it **crosses** that line?
What kind of line is this? Is it something from a study, or is it a drawing? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
