Date/Time: Thu, 26 Nov 2026 03:19:34 +0000
[User Discussion] - Dark Mode/Theme for Sierra Chart Title Bar - Windows 11
View Count: 2554
| [2025-09-23 12:35:38] |
| DonkeyEmporium - Posts: 4 |
I've been through the forum & realise that a dark mode for Sierra Chart has been discussed quite a bit before. I realise there are some issues with the compatibility of Windows and Sierra Chart due to it running in a Win32 frame - so DWM colouring doesn't have access to colour setting - neither does Sierra Chart from the app itself - Windows limits access to the frame settings for SC I've seen this youtube video which recommends switching to high contrast mode Tried that and it's too jarring for me: https://www.youtube.com/watch?v=qDRMHFbCAhc&t=108s QUESTION: Is there any other way to force the top title bar to a dark/black colour? See attached light-titlebar-win11.jpg Someone mentioned regedits - although this seems to be for Windows 10 - not Windows 11 (as I'm now running) - any regedits for Win 11? Otherwise any good/safe github projects that can do the job? |
| [2025-11-23 18:59:40] |
| User256728 - Posts: 3 |
I have done the regedit on Windows 11 and it makes the top of the window dark, I don't think it is possible to make the menu area dark.
| [2026-01-31 14:43:12] |
| Daniel - Backtesting.club - Posts: 177 |
The Title Bar can be changed easily via the settings in Windows 11. Unfortunately, the menu cannot.
| [2026-03-01 09:08:21] |
| User981449 - Posts: 52 |
Is the menu bar the only element that can’t be switched to dark mode without using external Windows themes like Rectify?
| [2026-03-01 11:51:47] |
| Rui S - Posts: 258 |
Try this: https://cleodesktop.gumroad.com/l/vrUdx?layout=discover&recommended_by=search&_gl=1 Date Time Of Last Edit: 2026-03-01 11:52:36
