Date/Time: Wed, 01 May 2024 12:28:58 +0000
Demo
View Count: 1601
[2014-10-11 17:56:15] |
User28031 - Posts: 2 |
H, I Have created demo trial at my 2nd notebook but it does not work. Data/trades settings says that data not enabled on package? What should I do? I wish to test more sch before purchasin. Thanks Regards |
[2014-10-13 23:25:25] |
Your account may need to be activated. We are checking on this now.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-13 23:25:36
[2014-10-13 23:28:52] |
Sierra Chart - Max - Posts: 5597 |
Your account has been activated and/or reset. A restart is necessary if Sierra Chart is already running. Exit the Sierra Chart charting and trading software by selecting "File >> Exit". Open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support |
[2014-10-14 08:58:16] |
thanks for help I appreciate it.
