Date/Time: Wed, 25 Nov 2026 22:42:32 +0000
Opening Bell Alert
View Count: 532
[2025-09-22 12:38:49]
Cileron - Posts: 52
Do you know what number alert for the time alert is the bell sound?
[2025-09-22 16:40:49]
To know the sound set for a particular alert, refer to the following:
General Settings Window: Sampling/Testing Sound Files
You can also use the "Alert Sound File Name" and "Test Sound" to review the different sounds available. Refer to the following:
General Settings Window: Sound File (Global Settings >> General Settings >> Alerts)
In the end, it is up to you to assign a sound to a particular alert and then use that alert where you want to. Refer to the following:
General Settings Window: Configuring Alert Number Instructions
[2025-09-22 17:33:07]
cmet - Posts: 747
Add this to your Alert Sounds folder if you don't have it.
attachmentopening-bell.wav - Attached On 2025-09-22 17:32:57 UTC - Size: 679.58 KB - 280 views
[2026-01-22 19:27:36]
User260640 - Posts: 21
I really like the crispness of the TOS opening bell instead.
Private File
