Date/Time: Wed, 25 Nov 2026 07:55:51 +0000
i cannot seem to export more than the current contract for MES
View Count: 409
| [2025-09-19 18:09:33] |
| User590541 - Posts: 1 |
I'm trying to download multiple contracts for MES data on the 1 minute scale- i updated my setting to use the continuous contract- and have seen the older contracts load into the log file- but i cannot seem to export one multicontract mes 1 minute txt file.
| [2025-09-19 18:50:28] |
| John - SC Support - Posts: 48648 |
You must be using the wrong export option. To export the data that is displayed in the chart as it is in the chart, use "Edit >> Export Bar Data to Text File". Refer to the following: Edit Menu: Edit >> Export Bar Data to Text File It sounds like you are using the "Edit >> Export Intraday Data to Text File", which exports a particular file's (contract's) contents. This would be the actual data that is stored for that symbol. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
