Date/Time: Fri, 03 May 2024 11:43:56 +0000
Study based on two studies/graphs
View Count: 904
[2014-10-11 05:06:00] |
NickH09 - Posts: 10 |
Hello, I would like to know if a study can be fed by two studies, i didnt found information in the acsil documentation to solve this problem. Thanks!!! |
[2014-10-11 07:36:41] |
Yes. A study can refer to the data from any number of studies using ACSIL.
[2014-10-11 21:58:32] |
Ok, Thanks!, I would like to know where can i find a reference of this subject in the documentation.
[2014-10-12 00:05:27] |
Right here: http://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#UsingStudyData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
