Date/Time: Tue, 03 Nov 2026 17:43:30 +0000
Live Data
View Count: 444
[2025-09-17 18:08:58]
Serajeddean - Posts: 8
Hello, hope this email finds you well.
Is there any way to possibly access real time data? If I attached a file correctly, I sent you my Sierra chart current package the $36 monthly package 5 that shows ES1 E-mini S&P500 running delayed data on, is there any way to possibly connect to a live data without needing a broker to open up an account on? Can't I do it directly on Sierra chart?
Thank you.
imageScreenshot 2025-09-17 200634.png / V - Attached On 2025-09-17 18:06:58 UTC - Size: 7.15 KB - 245 views
[2025-09-17 21:50:14]
John - SC Support - Posts: 48408
The only option without a brokerage account, is to pay the Professional exchange fees. To give you an idea of the cost, the CME Exchange with Market Depth for the Professionals is $150.00 per month. If you have a brokerage account that allows you to qualify as a Non-Professional, then the cost is $13.00 per month.
Refer to the following regarding the non-professional requirement for the CME Group:
Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
Also, in order to be able to get real-time data, you need to be on one of the "Integrated" packages. Right now, you are on the "Base Advanced" package. Refer to the information on the packages at the following link:
Description of Service Packages and Pricing: Packages
If you want to change your package, follow these instructions:
Sierra Chart Purchase and License Information: Changing Package
