Date/Time: Wed, 25 Nov 2026 07:56:02 +0000
message log keeps on popping up very frequently, covers significant part of the chart
View Count: 496
[2025-09-17 13:39:48]
User338887 - Posts: 2
Have one more issue though, perhaps you can help. My message log keeps on popping up very frequently and covers significant part of the chart, which I then need to quickly close to see what is happening in the markets.
Why does it happen so often? Is there some kind of connectivity / reconnection issue on my side that forces this process? How can I sort it out and avoid it?
And if there is some kind of connectivity issue on my side, which shows as a clear message in the message log, do I need to change my internet service provider?
Any help re this issue would be extremely helpful, as need to start somewhere...
Thank you kindly so much
Have a great day and Kindest Regards
T
Date Time Of Last Edit: 2025-09-17 13:39:58
[2025-09-17 16:03:18]
The only reason the Message Log opens is if there is something important to report in it. Please get us a copy of your Message Log so we can take a look and let you know what is showing in there that is causing it to open. Follow these instructions to get us your log:
In the meantime, there are two options to stop the log from continuously popping up on you:
1. Shrink down the size of the log and place it in a corner of your desktop out of the way somewhere.
2. There is a setting to not automatically open the Message Log. We do not recommend this, as the log is opening for a reason. But refer to the following:
General Settings Window: Never Automatically Open Message Log or Trade Service Log (Global Settings >> General Settings >> Log >> Log)
