Date/Time: Wed, 25 Nov 2026 21:36:15 +0000
Using Denali Data Feed with order routing through Rithmic
View Count: 1615
| [2025-09-16 23:20:43] |
| ssangha84 - Posts: 132 |
Hello, I want to use Denali data (CME Top-of-Book) for all charting and volume analysis, but I want to route trade orders through Rithmic directly from Sierra Chart. I have Denali properly activated and configured, and I’ve set: Allow Support for Sierra Chart Data Feeds = Yes Chart Symbol = ESZ25-CME Trade and Current Quote Symbol = ESZ5.CME Use As Trade Only Symbol = Yes Despite this, I still get the “Historical Intraday Data Download Failed: Exchange not specified” error while connected to Rithmic. Is there a way to make this setup work without getting that error? Thank you. |
| [2025-09-17 14:52:59] |
You do not need to use the "Trade and Current Quote Symbol" for this setup. Just set the symbol for what is needed for Rithmic, so in this case "ESZ5.CME". Sierra Chart is setup to know that you are connected to Rithmic and does the symbol translation "behind the scenes" for you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-02 02:27:29] |
| User944318 - Posts: 65 |
I am trying to do this as well. However, I am unable to access the denali data when I am connected and routing orders through rithmic.
| [2025-12-02 10:39:02] |
| User135243 - Posts: 337 |
Open your Rithmic connection and click "Common Settings" and there under "Common Other Settings" set "Allow Support Sierra Chart Data Feeds" to YES.
| [2025-12-02 16:44:00] |
Refer to the following to get the Options data from Sierra Chart when not connected to a Sierra Chart service: Denali Exchange Data Feed: Denali Futures Options Data with Other Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
