Date/Time: Wed, 25 Nov 2026 07:55:45 +0000
TPO Shading
View Count: 637
| [2025-09-16 22:33:33] |
| SpearChucker - Posts: 116 |
The later periods shading can be changed with -> TPO Letter/Block Color (SG13). Is it possible to change the starting periods darker shade color (I'd like to lighten it)?
| [2025-09-17 14:51:35] |
| John - SC Support - Posts: 48648 |
We are not understanding the question. The color of the letters/blocks is determined first from the Input for "TPO Letter/Block Colors". Refer to the following: Time Price Opportunity (TPO) Profile Charts: TPO Letter/Block Colors Then, if that is set to "Single Color" or "Separate Colors for Day and Evening Session", then the overall color is controlled by the "TPO Letter/Block Color" subgraph (SG13). But we do not know what you mean by "shading" or by "later periods" as it relates to coloring. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-17 18:41:46] |
This is what I'm referring to: Time Price Opportunity (TPO) Profile Charts: Shade TPO Letters/Blocks Based on Time On a black background the starting periods of the TPO are hard to see. I would like to lighten them a bit. See attachment. |
| [2025-09-17 21:58:18] |
The only thing you can do is to change the primary color of the "TPO Letter/Block Color" to make it lighter. This will lighten all the bars, including the darkest ones, but it is only a slight difference, so it may not do everything you want. We have set this as a Feature Request to have a way to set the low end of the colors shading used when shading the blocks/letters by time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
