Date/Time: Tue, 03 Nov 2026 17:42:59 +0000
Keep being disconnected from Sierra charts
View Count: 979
| [2025-09-15 14:06:19] |
| blazemk - Posts: 14 |
Hello Support, I keep being disconnected from Sierra charts my Error is code 10053: An established connection was aborted by the software in your host machine. The documentation online provides a limited explanation what exactly is the issue. Can i send the message log for analysis? Maybe there is a deeper issue. This has been happening since last week, before that I had no problems. |
| [2025-09-15 14:29:55] |
| Sierra_Chart Engineering - Posts: 25362 |
This indicates a connectivity problem. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Next time it happens provide the Message Log: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We just need to see the last 100 lines or so. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-09-15 14:30:15
| [2025-09-15 15:05:07] |
Posting below 2025-09-15 10:43:13.513 | Software version: 2789 64-bit 2025-09-15 10:43:13.513 | Primary Thread ID: 25728 2025-09-15 10:43:13.513 | Usage end date: 2026-04-30 2025-09-15 10:43:13.513 | Enabled for: Advanced Features 2. 2025-09-15 10:43:13.513 | Enabled for: Sierra Chart Historical Data Service. 2025-09-15 10:43:13.513 | Enabled for: Denali Real-Time Exchange Data Feed. 2025-09-15 10:43:13.513 | Enabled for: Delayed Denali Exchange Data Feed. 2025-09-15 10:43:13.513 | Enabled for exchange2: CME 2025-09-15 10:43:13.513 | Allow Support for Sierra Chart Data Feeds is enabled. 2025-09-15 10:43:13.513 | Current selected Data/Trading service: Teton CME Routing 2025-09-15 10:43:13.513 | Custom symbol settings values: disabled 2025-09-15 10:43:13.513 | Chart Update Interval: 500 2025-09-15 10:43:13.513 | Intraday Data Storage Time Unit: 0 2025-09-15 10:43:13.513 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) 2025-09-15 10:43:13.513 | 2025-09-15 14:43:13 Local computer time in UTC 2025-09-15 10:43:13.513 | 2025-09-15 10:43:13 Local computer time in SC Time Zone 2025-09-15 10:43:13.513 | 2025-09-15 14:27:46 Server time in UTC 2025-09-15 10:43:13.513 | Local computer UTC time and Server UTC time difference: 1 seconds. 2025-09-15 10:43:13.513 | Program path: D:\SierraChart\ 2025-09-15 10:43:13.513 | Data Files path: D:\SierraChart\Data\ 2025-09-15 10:43:13.513 | OS Version Number: 10.0 2025-09-15 10:43:13.513 | Locale Setting: C 2025-09-15 10:43:13.513 | Crash reporter started: true 2025-09-15 10:43:13.513 | 2025-09-15 10:44:41.211 | DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. 2025-09-15 10:44:41.211 | DTC Client socket (1) | Closed. 2025-09-15 10:44:41.211 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-09-15 10:45:11.217 | DTC Client socket (1) | Deleting network socket now after delay. 2025-09-15 10:52:22.329 | ESZ25_FUT_CME[M]/MESZ25_FUT_CME[M] 60 Min #3 | StartDateTimeForLoadingOrderFills: 2023-09-26 00:00:00 2025-09-15 10:52:22.336 | ESZ25_FUT_CME[M]/MESZ25_FUT_CME[M] 2000 Trades #2 | StartDateTimeForLoadingOrderFills: 2024-09-08 00:00:00 2025-09-15 10:52:22.344 | ESZ25_FUT_CME[M]/MESZ25_FUT_CME[M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 2024-09-08 00:00:00 2025-09-15 10:52:22.352 | ESZ25_FUT_CME/MESZ25_FUT_CME[M] 1 Min #4 | StartDateTimeForLoadingOrderFills: 00:09:30 2025-09-15 10:52:22.361 | ESZ25_FUT_CME[M] 5.00 Range #5 | StartDateTimeForLoadingOrderFills: 00:09:30 2025-09-15 10:57:11.694 | Teton CME Routing | There has been no activity on the network socket for 44s. Will reconnect. 2025-09-15 10:57:11.694 | Connection to the external service has been lost. 2025-09-15 10:57:11.709 | Teton CME Routing | Waiting for socket receive thread to end 2025-09-15 10:57:11.710 | DTC Client socket (4) | CloseSocket call. 2025-09-15 10:57:11.710 | DTC Client socket (4) | Max send buffers used during socket life: 3 2025-09-15 10:57:11.710 | DTC Client socket (4) | Max send buffer size during socket life: 233 2025-09-15 10:57:11.710 | DTC Client socket (4) | Shutdown started. Waiting for graceful close. 2025-09-15 10:57:11.710 | Teton CME Routing | Disconnected. 2025-09-15 10:57:11.710 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-09-15 10:57:13.705 | 2025-09-15 10:57:13.705 | Teton CME Routing | Firm: IronBeam 2025-09-15 10:57:13.705 | Teton CME Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085 2025-09-15 10:57:13.706 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2025-09-15 10:57:13.706 | DTC Client socket (1) | New receive buffer size: 0 2025-09-15 10:57:13.706 | DTC Client socket (1) | Connecting to IP: 208.185.224.130. 2025-09-15 10:57:13.957 | Teton CME Routing | Network connection to server complete. 2025-09-15 10:57:13.957 | Teton CME Routing | Starting socket receive thread. 2025-09-15 10:57:13.957 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2025-09-15 10:57:33.968 | Teton CME Routing | Did not receive Encoding Response from server. Disconnecting. * 2025-09-15 10:57:33.968 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-09-15 10:57:33.968 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-09-15 10:57:33.984 | Teton CME Routing | Waiting for socket receive thread to end 2025-09-15 10:57:33.984 | DTC Client socket (1) | CloseSocket call. 2025-09-15 10:57:33.984 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2025-09-15 10:57:33.984 | Teton CME Routing | Disconnected. 2025-09-15 10:57:33.984 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-09-15 10:57:35.975 | 2025-09-15 10:57:35.975 | Teton CME Routing | Firm: IronBeam 2025-09-15 10:57:35.975 | Teton CME Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085 2025-09-15 10:57:35.976 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-09-15 10:57:35.976 | DTC Client socket (2) | New receive buffer size: 0 2025-09-15 10:57:35.976 | DTC Client socket (2) | Connecting to IP: 208.185.224.130. 2025-09-15 10:57:36.220 | Teton CME Routing | Network connection to server complete. 2025-09-15 10:57:36.220 | Teton CME Routing | Starting socket receive thread. 2025-09-15 10:57:36.220 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2025-09-15 10:57:49.865 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-09-15 10:57:49.865 | DTC Client socket (1) | Closed. 2025-09-15 10:57:56.229 | Teton CME Routing | Did not receive Encoding Response from server. Disconnecting. * 2025-09-15 10:57:56.229 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-09-15 10:57:56.229 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-09-15 10:57:56.245 | Teton CME Routing | Waiting for socket receive thread to end 2025-09-15 10:57:56.245 | DTC Client socket (2) | CloseSocket call. 2025-09-15 10:57:56.245 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2025-09-15 10:57:56.245 | Teton CME Routing | Disconnected. 2025-09-15 10:57:56.245 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-09-15 10:57:58.244 | 2025-09-15 10:57:58.244 | Teton CME Routing | Firm: IronBeam 2025-09-15 10:57:58.244 | Teton CME Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085 2025-09-15 10:57:58.501 | DTC Client socket (5) | Creating socket. Using TLS 1.2. 2025-09-15 10:57:58.501 | DTC Client socket (5) | New receive buffer size: 0 2025-09-15 10:57:58.501 | DTC Client socket (5) | Connecting to IP: 208.185.224.130. 2025-09-15 10:57:58.745 | Teton CME Routing | Network connection to server complete. 2025-09-15 10:57:58.745 | Teton CME Routing | Starting socket receive thread. 2025-09-15 10:57:58.745 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2025-09-15 10:58:00.125 | Teton CME Routing | Setting DTC encoding to Binary VLS 2025-09-15 10:58:00.125 | Teton CME Routing | Sending logon request message. 2025-09-15 10:58:02.008 | Teton CME Routing | Received logon response. 2025-09-15 10:58:02.008 | Teton CME Routing | Server Name: SC DTC Server. Build=53594. 2025-09-15 10:58:02.008 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2025-09-15 10:58:02.008 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2025-09-15 10:58:02.008 | Teton CME Routing | Trading is supported. 2025-09-15 10:58:02.008 | Teton CME Routing | Order cancel and replace is supported. 2025-09-15 10:58:02.008 | Teton CME Routing | OCO Orders supported. 2025-09-15 10:58:02.008 | Teton CME Routing | Bracket Orders supported. 2025-09-15 10:58:02.008 | Teton CME Routing | MarketDepthIsSupported: 1 2025-09-15 10:58:02.008 | Teton CME Routing | Connection to server complete. 2025-09-15 10:58:02.008 | Denali Data Feed | Waiting for socket receive thread to end 2025-09-15 10:58:02.009 | DTC Client socket (3) | CloseSocket call. 2025-09-15 10:58:02.009 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2025-09-15 10:58:02.009 | Denali Data Feed | Disconnected from the server. 2025-09-15 10:58:02.009 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-09-15 10:58:02.009 | Updated verified funded futures trading account ending date to: 2025-10-15 14:58:02 2025-09-15 10:58:02.010 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2025-09-15 10:58:02.021 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2025-09-15 14:34:10.943850 2025-09-15 10:58:02.456 | Mapping MESZ25_FUT_CME to MESZ25. Service code: cme 2025-09-15 10:58:02.456 | Using symbol data fast lookup vector 2025-09-15 10:58:02.456 | Denali Data Feed | Starting real-time market data updates for: MESZ25_FUT_CME (MESZ25). ID: 1 Service code: cme 2025-09-15 10:58:02.456 | Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 443 2025-09-15 10:58:02.456 | Denali Data Feed | Requesting security definition data for: MESZ25_FUT_CME (MESZ25). ID: 1 2025-09-15 10:58:02.456 | Mapping ESZ25_FUT_CME to ESZ25. Service code: cme 2025-09-15 10:58:02.456 | Denali Data Feed | Starting real-time market data updates for: ESZ25_FUT_CME (ESZ25). ID: 2 Service code: cme 2025-09-15 10:58:02.456 | Denali Data Feed | Requesting security definition data for: ESZ25_FUT_CME (ESZ25). ID: 2 2025-09-15 10:58:02.456 | Added historical Intraday data request for ESZ25_FUT_CME to the queue. 2025-09-15 10:58:02.456 | Intraday data recording state for symbol ESZ25_FUT_CME is set to download 'Pending'. 2025-09-15 10:58:02.456 | Triggering next historical data download in queue. 2025-09-15 10:58:02.456 | DTC Client socket (1) | Creating socket. 2025-09-15 10:58:02.456 | DTC Client socket (1) | New receive buffer size: 0 2025-09-15 10:58:02.456 | DTC Client socket (1) | Connecting to IP: 64.152.155.18. 2025-09-15 10:58:02.465 | Delaying start of download for ESZ25_FUT_CME. 2025-09-15 10:58:02.543 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-09-15 10:58:02.543 | DTC Client socket (3) | Closed. 2025-09-15 10:58:02.661 | Denali Data Feed | Network connection to server complete. 2025-09-15 10:58:02.661 | Denali Data Feed | Starting socket receive thread. 2025-09-15 10:58:02.661 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-09-15 10:58:02.886 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-09-15 10:58:02.886 | Denali Data Feed | Sending logon request message. 2025-09-15 10:58:03.544 | Denali Data Feed | Received logon response. 2025-09-15 10:58:03.544 | Denali Data Feed | Server Name: SC Realtime Server. 2025-09-15 10:58:03.544 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-09-15 10:58:03.544 | Denali Data Feed | Successfully connected. 2025-09-15 10:58:03.544 | Denali Data Feed | Trading is not supported. 2025-09-15 10:58:03.544 | Denali Data Feed | MarketDepthIsSupported: 1 2025-09-15 10:58:03.544 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ25_FUT_CME -> ESZ25 2025-09-15 10:58:03.544 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ25_FUT_CME -> MESZ25 2025-09-15 10:58:03.854 | Denali Data Feed | Setting external service identifier for symbol ESZ25_FUT_CME to 294973 2025-09-15 10:58:03.854 | Denali Data Feed | Received security definition for symbol ESZ25_FUT_CME 2025-09-15 10:58:03.854 | Denali Data Feed | Setting external service identifier for symbol MESZ25_FUT_CME to 42004164 2025-09-15 10:58:03.854 | Denali Data Feed | Received security definition for symbol MESZ25_FUT_CME 2025-09-15 10:58:05.806 | Updated verified funded futures trading account ending date to: 2025-10-15 14:58:05 2025-09-15 10:58:07.007 | Requesting market depth updates for: ESZ25_FUT_CME if supported. NumLevels=100 2025-09-15 10:58:07.007 | Requesting market depth updates for: MESZ25_FUT_CME if supported. NumLevels=100 2025-09-15 10:58:07.261 | Denali Data Feed | Clearing market depth for ESZ25_FUT_CME 2025-09-15 10:58:07.261 | Denali Data Feed | Clearing market depth for MESZ25_FUT_CME 2025-09-15 10:58:08.454 | HD Request # 6 | Downloading Intraday chart data for ESZ25_FUT_CME to the file ESZ25_FUT_CME.scid. Service: cme 2025-09-15 10:58:08.455 | HD Request # 6 | Download start date-time: 2025-09-15 10:57:31.000000. File last date-time: 2025-09-15 10:57:31.389017 2025-09-15 10:58:08.455 | HD Request # 6 | Using server: ds28.sierracharts.com port 10149 2025-09-15 10:58:08.455 | Socket (3) | Creating socket. 2025-09-15 10:58:08.455 | Socket (3) | New receive buffer size: 0 2025-09-15 10:58:08.455 | Socket (3) | Connecting to IP: 67.214.125.5. 2025-09-15 10:58:08.943 | HD Request # 6 | Setting DTC encoding to Binary VLS 2025-09-15 10:58:08.943 | HD Request # 6 | Sending historical data logon request message. 2025-09-15 10:58:09.228 | HD Request # 6 | Requesting Intraday data. Start date-time: 2025-09-15 10:57:31. Record interval: 0. Symbol: ESZ25 2025-09-15 10:58:09.476 | HD Request # 6 | Decompressing data. 2025-09-15 10:58:09.719 | HD Request # 6 | Receiving Intraday data for ESZ25_FUT_CME starting at 2025-09-15 10:57:31.102000 2025-09-15 10:58:09.720 | Socket (3) | CloseSocket call. 2025-09-15 10:58:09.720 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-09-15 10:58:09.720 | Historical data download thread signaled to stop. 2025-09-15 10:58:09.720 | HD Request # 6 | Timestamp of first Intraday data file record written: 2025-09-15 10:57:38.900000. 2025-09-15 10:58:09.720 | HD Request # 6 | Received 435 Intraday data records from 2025-09-15 10:57:31.102000 to 2025-09-15 10:58:08.323000 (37.2 seconds. Delay: 1.4 seconds) and wrote 395 records for ESZ25_FUT_CME 2025-09-15 10:58:09.720 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2025-09-15 14:58:08.323000 2025-09-15 10:58:09.720 | Added 72 Time and Sales records to Intraday data file for ESZ25_FUT_CME after download. 2025-09-15 10:58:09.721 | HD Request # 6 | Completion time: 1s. 2025-09-15 10:58:09.721 | HD Request # 6 | Intraday data download complete for ESZ25_FUT_CME. Unique request ID: 6 2025-09-15 10:58:09.721 | Removing historical data download ID 6. 2025-09-15 10:58:09.721 | Real-time Intraday chart data file updates started for ESZ25_FUT_CME 2025-09-15 10:58:09.721 | Intraday chart data file opened for ESZ25_FUT_CME 2025-09-15 10:58:09.721 | HD Request # 6 | Enabling Intraday chart updating for symbol. 2025-09-15 10:58:09.721 | 2025-09-15 10:58:09.721 | No download requests in the queue to start downloads for. 2025-09-15 10:58:09.961 | Socket (3) | Socket gracefully closed by remote side. 2025-09-15 10:58:09.961 | Socket (3) | Closed. 2025-09-15 10:58:15.418 | Opened cached Intraday file: D:\SierraChart\Data\ESZ25_FUT_CME.scid. Thread ID: 28344 2025-09-15 10:58:27.663 | DTC Client socket (4) | Socket gracefully closed by remote side. 2025-09-15 10:58:27.663 | DTC Client socket (4) | Closed. 2025-09-15 10:58:39.274 | Teton CME Routing | Received final trade activity snapshot. Count=22. TradeAccount=23088821 2025-09-15 10:58:39.517 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESZ25_FUT_CME 2025-09-15 10:58:39.517 | Teton CME Routing | Setting external service identifier for symbol MESZ25_FUT_CME to 42004164 2025-09-15 10:58:39.517 | Teton CME Routing | Received security definition for symbol MESZ25_FUT_CME 2025-09-15 10:58:39.517 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESZ25_FUT_CME 2025-09-15 10:58:39.517 | Teton CME Routing | Setting external service identifier for symbol ESZ25_FUT_CME to 294973 2025-09-15 10:58:39.517 | Teton CME Routing | Received security definition for symbol ESZ25_FUT_CME 2025-09-15 10:59:56.493 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-09-15 10:59:56.493 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-09-15 10:59:56.494 | DTC Client socket (2) | Closed. |
| [2025-09-15 15:48:42] |
Can you check with your ISP and see if they are blocking port 11085?: 2025-09-15 10:57:13.705 | Teton CME Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-16 15:36:37] |
I ran a test on this port and it seems to be closed.
| [2025-09-17 13:27:25] |
I also de receive a message as a pop up window which says : Teton CME routing | Logon error received from server: Secondary instance is not allowing connections to this server | Date- Time :2025-09-17 09:09:05 I am not sure what secondary instance means here. |
| [2025-09-17 13:39:52] |
If the port is getting blocked, you need to use a different ISP. Regarding post #6, that message can be disregarded. It is not relevant to the issue and causes no problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-09-17 13:40:57
| [2025-09-18 10:58:30] |
Actually I found out the whole UAE was affected by internet issues since last week due to Red Sea underwater cables being cut. So I may have to just wait until they fix the problem. I am not sure if anybody else reached out to you from UAE regarding this but this could be the reason for disconnections. The problems started exactly the same time as the cables were cut.
