Date/Time: Sat, 07 Nov 2026 11:28:55 +0000
RTY Rollover
View Count: 489
[2025-09-11 12:44:54]
User731023 - Posts: 167
RTY contract shows need to rollover even though not set for Volume.
Also no in General for volume rollover.
Even tried no rollover. Can't get it off unless I rollover.
imageBulkowski.jpg / V - Attached On 2025-09-11 12:44:44 UTC - Size: 35.17 KB - 263 views
[2025-09-11 16:19:25]
John - SC Support - Posts: 48459
When you receive the rollover notification and you do not want to rollover, just do not rollover and that message will go away after a few minutes.
As to the notice, you should only be getting a notification of a Volume rollover if you have the following setting set to "Yes", but you state that it is set to "No":
General Settings Window: Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume (Global Settings >> General Settings >> Charts >> Symbol)
[2025-09-11 19:10:00]
Thanks,
Had to restart Sierra for it to go away. Just letting you know.
