Date/Time: Wed, 18 Nov 2026 07:14:35 +0000
Help with highlighting footprint
View Count: 1157
| [2025-09-08 19:10:55] |
| User913209 - Posts: 9 |
Hello Sierra Chart Support, I am using version 2776 (64-bit) with the Denali feed. I understand that Unfinished Auctions (when there is no opposite Bid/Ask at the high/low) and Exhaustions (when there is zero Bid or Ask volume inside the bar) can already be seen in the numbers on the footprint. However, for fast trading it is very difficult to spot them manually. 👉 I would like Sierra Chart to automatically highlight (color background or marker) these cases directly on the footprint bars: Unfinished Auctions at the high/low Exhaustions (0 Bid or 0 Ask volume) Could you please tell me the exact study or settings to use to achieve this highlight? Thank you very much for your help. Best regards, |
| [2025-09-08 21:35:56] |
| John - SC Support - Posts: 48568 |
Refer to the following regarding the Unfinished Auction and the two Inputs below it: Numbers Bars: Highlight Nonzero Bid&Ask Volume at High/Low As to Exhaustions, there is nothing built into the Numbers Bars to highlight this situation. You would need to use the "Color Bar Based on Alert Condition" to find and highlight when this occurs. Refer to examples 41, 42, and 43 at the following: Study/Chart Alerts And Scanning: Alert Formula Examples And refer to the following: Color Bar Based on Alert Condition For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
