Date/Time: Fri, 03 May 2024 13:18:05 +0000
error on conection
View Count: 1456
[2013-05-13 09:16:55] |
This error means: The requested name is valid, but no data of the requested type was found. This is a DNS problem on your computer. Probably the easiest thing to do is to restart the computer. If you still have difficulty, then on your desktop go to Start >> Settings >>Network Connections. Right-click on the network connection and select Diagnose. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
