Date/Time: Wed, 25 Nov 2026 07:55:57 +0000
[Programming Help] - How to access options data
View Count: 1104
| [2025-09-04 10:34:27] |
| User944318 - Posts: 65 |
How to access options data from an ACSIL study?
| [2025-09-04 15:25:21] |
| John - SC Support - Posts: 48648 |
The actual data itself is not any different from any other data, so you would access the data through the sc.BaseData[][] variable. Refer to the following: ACSIL Interface Members - Variables and Arrays: sc.BaseDataIn[][] / sc.BaseData[][] For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-06 21:45:15] |
How do I reference a specific option? What is the format in terms of underlying asset, strike price, expiration date?
| [2025-09-08 14:54:45] |
In general, you need to open a chart in order to get the data. If you want to open a chart using ACSIL, then you will need to take a look at the symbol format for the service you are using. Refer to the following: Denali Exchange Data Feed: Denali Futures Options For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-08 15:27:13] |
How do I access options data as a secondary series from an ACSIL study, what function would I call? I tried to look up the option codes, but when I clicked on ES and then Get Options, nothing happened.
| [2025-09-08 15:33:25] |
| Sierra_Chart Engineering - Posts: 25479 |
Update Sierra Chart to the current version: Software Download: Fast Update And try again: but when I clicked on ES and then Get Options, nothing happened.
We do not know what you mean by this but there is no way to get an option chain from ACSIL: How do I access options data as a secondary series from an ACSIL study, what function would I call?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-09-08 15:34:13
| [2025-09-08 16:10:23] |
Can I get the current price of ES call option expiring next week at strike price X in acsil?
