Date/Time: Wed, 25 Nov 2026 07:55:54 +0000
Auto Adjust CHart
View Count: 421
| [2025-09-04 00:22:06] |
| Cileron - Posts: 52 |
Is there a way to auto adjust chart to left as new bars are printed so it doesn’t go off the screen?
| [2025-09-04 15:09:42] |
| John - SC Support - Posts: 48648 |
We are not fully understanding your question. As long as the most current bar is visible, then any new bars that are added will also be visible, either by adding to the right of the current bar or by shifting the entire chart to the left by one bar - depending on how much graphics area is available and the location of that most current bar, and also depending on the following setting: General Settings Window: Allow New Data In Unlocked Fill Space (Global Settings >> General Settings >> Charts >> Charts) The converse is also true, if you have scrolled back to view something previous in a chart and the most current bar is not visible, then the chart will remain in the current location. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
