Date/Time: Wed, 25 Nov 2026 07:56:05 +0000
Configuration Button Assignment
View Count: 453
| [2025-09-03 13:17:53] |
| User296553 - Posts: 21 |
How do I assignt buttons to this new update on configurations? or is it not possible?
| [2025-09-03 15:52:23] |
| John - SC Support - Posts: 48648 |
What do you mean by buttons? If you are referring to Control Bar Buttons, then that has not changed at all. Refer to the following: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
