Date/Time: Fri, 03 May 2024 10:50:53 +0000
Comparing time frames
View Count: 824
[2014-10-09 20:59:38] |
User20702 - Posts: 13 |
Can two charts be set up through linking that would for example have one chart on 6T renco and the other on 1T rencos, and when moving from bar to bar on the 6T it would shade the 1T candles that are inside the 6T? Thanks Dave |
[2014-10-09 21:41:23] |
There is no built-in support for this, but there might be a user contributed study that does this.
