Date/Time: Sat, 04 May 2024 04:42:04 +0000
Empty tick data
View Count: 909
[2014-10-09 18:17:01] |
User210779 - Posts: 5 |
Hello, if I open chart with e-mini S&P 500 (EPZ14) or another one, set time frame to 1sec and use tick data. Chart or Spreadsheet Study contain empty data (some where there is a zero price value). It is a big problem for me. I want to trade spread between two contract months. But if I don't have all data it is not possible. I test it wit TTnet and CQG data feed. Can you help me please? |
[2014-10-09 18:29:11] |
This is not a valid symbol: EPZ14 Locate the correct symbol through File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-09 18:45:23] |
all symbol is F.US.EPZ14 it is from File>>Find Symbol
[2014-10-09 21:59:37] |
Refer to help topic 7 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails7.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
