Date/Time: Wed, 25 Nov 2026 07:55:50 +0000
Is my Footprint live
View Count: 479
| [2025-08-29 14:51:24] |
| kero kero - Posts: 8 |
When i run a new instance to get footprint data i'm not sure it's live, it doesn't show the [M] unlike first instance, even tho it works. So i'm gonna put XX$ on my sierra account and verify if this runs properly. Pardon me for the delay it's 5AM in Europe, Regards, E. |
| [2025-08-29 15:32:37] |
| Sierra_Chart Engineering - Posts: 25479 |
You will not see the [M] in a sub instance: Chart Data and Chart Data Files: The Meaning of the [M] Designation after a Symbol You can check for the data delay using the Data Delay (DD) field: Working With Charts: Region Data Line / Chart Header Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-08-29 15:33:31
