Date/Time: Wed, 25 Nov 2026 07:55:49 +0000
VWAP Bottom2 SG5 band won't show value seems to be a bug
View Count: 561
[2025-08-27 18:13:42]
TopGunTrader - Posts: 313
The VWAP bottom band 2 SG5 won't show the value, I tried many places but in this case its right side value scale.
imageCapture.PNG / V - Attached On 2025-08-27 18:13:35 UTC - Size: 104.38 KB - 230 views
[2025-08-27 18:48:55]
Please get us that chart so we can take a look. Follow these instructions to get us a chart:
[2025-08-28 02:51:55]
I noticed tonight fuzzy black writing for price and inverted the colors and then it showed up so that may be the bug here is workspace.
[2025-08-28 02:52:20]
Sorry here is workspace
attachmentChartbook6.Cht - Attached On 2025-08-28 02:52:10 UTC - Size: 3.92 KB - 215 views
[2025-08-28 15:14:57]
For some reason, and we have no idea why, the colors are set to be "reversed" even though the option is not checked. This is causing the text to be drawn as black, which is why you can not see it.
If you remove the study and then add another one back to the chart, then let us know if the problem persists, as we do not think it will. Note that when you add the VWAP study back, you need to do it from "Analysis >> Studies". Do not use a Study Collection or any other source for the study, as that could be the source of the issue.
[2025-08-28 17:44:05]
I removed and added it same issue like you said its blacked out. Every other time I use reverse colors it uses the color as background and text becomes black.
On your version when you add vwap and show Bottom Band 2 SG5 and check value label right side value does it work? I can't believe its only me it won't work on. When I click reverse colors it does show up but not the color as background as in every other study.
imageCapture.PNG / V - Attached On 2025-08-28 17:44:00 UTC - Size: 240.41 KB - 270 views
[2025-08-28 19:15:25]
When we use your chart and remove the old study and then add a new one on the chart, the label shows correctly in the price scale. In the image, we only turned on the Value Label for the Bottom Band 2 (SG5), which is the one you had the issues with.
We see that the VWAP you put on has the same colors and setup as the one that was on the chart previously. Is this a saved set of defaults for this study for you? You may need to delete that default and then set it up again. Or, if you used a Study Collection, then do not do that, as the Study Collection is somehow corrupted.
Refer to the following regarding the default study settings:
Chart Studies: Using Custom Default Study Settings
