Date/Time: Wed, 25 Nov 2026 16:03:08 +0000
Is it possible to to delete a candle or the candles volume?
View Count: 442
[2025-08-27 13:46:27]
User907609 - Posts: 18
Hi, is there a built in function in sierra to delete a candle and its volume or just volume, or is it possible to code something that can delete the volume for a candle?
reason I ask the 8am prints on stocks throws all the volume indcators off like delta so id like to delete say the 8am candle volume to regain somewhat clean data.
I know you can select the candle and delte trade records and it does the job but you have to spend maybe 5 minutes at time doing this when you could just make a button to do it.
TIA!
[2025-08-27 14:42:07]
Sierra_Chart Engineering - Posts: 25481
The only way to do this is to adjust the session times to exclude, data from a particular time. Although this is going to exclude everything before the time as well.
For example, you could set the start time to 08:00:01. We do not know what the start time was previously.
Refer to:
Chart Session Times
