Date/Time: Wed, 25 Nov 2026 16:03:06 +0000
KE default Symbol Settings causing gap in continuous chart
View Count: 1302
| [2025-09-02 19:17:00] |
| juicebro - Posts: 119 |
Is not Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Days to Load >> Days to Load for Historical/Intraday Chart Data Type irrelevant when I have selected Load Data Limiting Method >> Use Date Range ?I have attached my Data Limiting settings for MCL, which I have changed the Date Range From from previously 2000-01-02, to 2021-07-11 which is within range of the data your servers provide.I deleted and redownloaded all MCL data with these settings, but when I restart sierra I still see logs requesting data from 1923, 1922, etc. on startup. Am I still doing something wrong? Date Time Of Last Edit: 2025-09-02 19:23:00
| [2025-09-02 19:31:38] |
and there should not be any historical data request for expired symbols once they are downloaded once.
Perhaps I misunderstand you, but what you said does not seem to be the case.This is a portion of my logs after changing my MCL settings as mentioned above, successfully deleting and redownloading the data, then quitting and restarting sierra. Since the data was redownloaded I see no reason why it is again requesting data on every startup. I have 9 futures charts open currently, all micros, and MCL is the only one doing this. 2025-09-02 11:45:31.620 | HD Request # 10 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:31.620 | HD Request # 10 | Sending historical data logon request message. 2025-09-02 11:45:31.696 | HD Request # 10 | Requesting Intraday data. Start date-time: 2021-06-02 17:00:00. Record interval: 60. Symbol: MCLQ21 2025-09-02 11:45:31.773 | HD Request # 10 | Decompressing data. 2025-09-02 11:45:31.808 | HD Request # 10 | Receiving Intraday data for MCLQ21 starting at 2021-07-11 15:07:50.205000 2025-09-02 11:45:31.808 | HD Request # 10 | Truncating file to starting date-time of 2021-07-11 15:07:50.205. 2025-09-02 11:45:32.145 | Socket (11) | CloseSocket call. 2025-09-02 11:45:32.145 | Socket (11) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:32.145 | Historical data download thread signaled to stop. 2025-09-02 11:45:32.146 | HD Request # 10 | Timestamp of first Intraday data file record written: 2021-07-11 15:07:50.205000. 2025-09-02 11:45:32.146 | HD Request # 10 | Received 5676 Intraday data records from 2021-07-11 15:07:50.205000 to 2021-07-19 11:28:23.494000 (7.8 days. Delay: 4.1 years) and wrote 5676 records for MCLQ21 2025-09-02 11:45:32.146 | HD Request # 10 | Completion time: 4s. 2025-09-02 11:45:32.146 | HD Request # 10 | Intraday data download complete for MCLQ21. Unique request ID: 9 2025-09-02 11:45:32.146 | Removing historical data download ID 9. 2025-09-02 11:45:32.146 | Real-time Intraday chart data file updates started for MCLQ21 2025-09-02 11:45:32.146 | File compression not supported on file system. C:\ProgramData\SierraChart\Data\MCLQ21.scid. Windows error code 50: Request not supported. 2025-09-02 11:45:32.146 | Opened cached Intraday file: C:\ProgramData\SierraChart\Data\MCLQ21.scid. Thread ID: 232 2025-09-02 11:45:32.146 | Intraday chart data file opened for MCLQ21 2025-09-02 11:45:32.146 | HD Request # 10 | Enabling Intraday chart updating for symbol. 2025-09-02 11:45:32.146 | 2025-09-02 11:45:32.146 | Triggering next historical data download in queue. 2025-09-02 11:45:32.146 | Mapping MCLV25 to MCLV25. Service code: nymex 2025-09-02 11:45:32.146 | HD Request # 11 | Downloading Intraday chart data for MCLV25 to the file MCLV25.scid. Service: nymex 2025-09-02 11:45:32.146 | File compression not supported on file system. C:\ProgramData\SierraChart\Data\MCLV25.scid. Windows error code 50: Request not supported. 2025-09-02 11:45:32.147 | HD Request # 11 | Download start date-time: 2025-09-02 11:34:05.000000. File last date-time: 2025-09-02 11:34:05.193000 2025-09-02 11:45:32.147 | HD Request # 11 | Using server: ds28.sierracharts.com port 10150 2025-09-02 11:45:32.147 | Socket (7) | Creating socket. 2025-09-02 11:45:32.147 | Socket (7) | New receive buffer size: 5242880 2025-09-02 11:45:32.147 | Socket (7) | Connecting to IP: 67.214.125.5. 2025-09-02 11:45:32.219 | Socket (11) | Socket gracefully closed by remote side. 2025-09-02 11:45:32.219 | Socket (11) | Closed. 2025-09-02 11:45:32.313 | HD Request # 11 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:32.313 | HD Request # 11 | Sending historical data logon request message. 2025-09-02 11:45:32.391 | HD Request # 11 | Requesting Intraday data. Start date-time: 2025-09-02 11:34:05. Record interval: 60. Symbol: MCLV25 2025-09-02 11:45:32.466 | HD Request # 11 | Decompressing data. 2025-09-02 11:45:32.536 | HD Request # 11 | Receiving Intraday data for MCLV25 starting at 2025-09-02 11:34:05.193000 2025-09-02 11:45:32.537 | Socket (7) | CloseSocket call. 2025-09-02 11:45:32.537 | Socket (7) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:32.538 | Historical data download thread signaled to stop. 2025-09-02 11:45:32.538 | HD Request # 11 | Timestamp of first Intraday data file record written: 2025-09-02 11:34:05.193000. 2025-09-02 11:45:32.538 | HD Request # 11 | Received 2 Intraday data records from 2025-09-02 11:34:05.193000 to 2025-09-02 11:35:04.774000 (59.6 seconds. Delay: 10.5 minutes) and wrote 2 records for MCLV25 2025-09-02 11:45:32.538 | HD Request # 11 | Completion time: 0s. 2025-09-02 11:45:32.538 | HD Request # 11 | Intraday data download complete for MCLV25. Unique request ID: 10 2025-09-02 11:45:32.538 | Removing historical data download ID 10. 2025-09-02 11:45:32.538 | Real-time Intraday chart data file updates started for MCLV25 2025-09-02 11:45:32.538 | File compression not supported on file system. C:\ProgramData\SierraChart\Data\MCLV25.scid. Windows error code 50: Request not supported. 2025-09-02 11:45:32.538 | Opened cached Intraday file: C:\ProgramData\SierraChart\Data\MCLV25.scid. Thread ID: 232 2025-09-02 11:45:32.538 | Intraday chart data file opened for MCLV25 2025-09-02 11:45:32.538 | HD Request # 11 | Enabling Intraday chart updating for symbol. 2025-09-02 11:45:32.538 | 2025-09-02 11:45:32.538 | Triggering next historical data download in queue. 2025-09-02 11:45:32.538 | Mapping MCLH23 to MCLH23. Service code: nymex 2025-09-02 11:45:32.539 | HD Request # 12 | Downloading Historical Daily chart data for MCLH23. Starting date: 1923-04-25. Service: nymex 2025-09-02 11:45:32.539 | HD Request # 12 | Using server: ds26.sierracharts.com port 10149 2025-09-02 11:45:32.539 | Socket (11) | Creating socket. 2025-09-02 11:45:32.539 | Socket (11) | New receive buffer size: 5242880 2025-09-02 11:45:32.539 | Socket (11) | Connecting to IP: 64.152.155.17. 2025-09-02 11:45:32.611 | Socket (7) | Socket gracefully closed by remote side. 2025-09-02 11:45:32.611 | Socket (7) | Closed. 2025-09-02 11:45:32.694 | HD Request # 12 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:32.694 | HD Request # 12 | Sending historical data logon request message. 2025-09-02 11:45:32.769 | HD Request # 12 | Requesting historical Daily data starting at 1923-04-25. 2025-09-02 11:45:32.840 | HD Request # 12 | Decompressing data. 2025-09-02 11:45:32.845 | HD Request # 12 | Receiving historical Daily data for MCLH23 starting at 2022-02-07. 2025-09-02 11:45:32.845 | HD Request # 12 | Writing historical Daily data to the file MCLH23.dly. 2025-09-02 11:45:32.858 | Socket (11) | CloseSocket call. 2025-09-02 11:45:32.859 | Socket (11) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:32.859 | Historical data download thread signaled to stop. 2025-09-02 11:45:32.859 | HD Request # 12 | Received 256 Daily data records from 2022-02-07 00:00:00 to 2023-02-03 00:00:00 (362.0 days) and wrote 256 records for MCLH23 2025-09-02 11:45:32.859 | HD Request # 12 | Completion time: 0s. 2025-09-02 11:45:32.859 | HD Request # 12 | Daily data download complete for MCLH23. Unique request ID: 11 2025-09-02 11:45:32.859 | Removing historical data download ID 11. 2025-09-02 11:45:32.859 | 2025-09-02 11:45:32.859 | Triggering next historical data download in queue. 2025-09-02 11:45:32.860 | Mapping MCLG23 to MCLG23. Service code: nymex 2025-09-02 11:45:32.860 | HD Request # 13 | Downloading Historical Daily chart data for MCLG23. Starting date: 1923-03-25. Service: nymex 2025-09-02 11:45:32.861 | HD Request # 13 | Using server: ds32.sierracharts.com port 10150 2025-09-02 11:45:32.861 | Socket (7) | Creating socket. 2025-09-02 11:45:32.861 | Socket (7) | New receive buffer size: 5242880 2025-09-02 11:45:32.862 | Socket (7) | Connecting to IP: 69.39.70.248. 2025-09-02 11:45:32.932 | Socket (11) | Socket gracefully closed by remote side. 2025-09-02 11:45:32.932 | Socket (11) | Closed. 2025-09-02 11:45:33.016 | HD Request # 13 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:33.016 | HD Request # 13 | Sending historical data logon request message. 2025-09-02 11:45:33.094 | HD Request # 13 | Requesting historical Daily data starting at 1923-03-25. 2025-09-02 11:45:33.166 | HD Request # 13 | Decompressing data. 2025-09-02 11:45:33.169 | HD Request # 13 | Receiving historical Daily data for MCLG23 starting at 2022-01-06. 2025-09-02 11:45:33.170 | HD Request # 13 | Writing historical Daily data to the file MCLG23.dly. 2025-09-02 11:45:33.183 | Socket (7) | CloseSocket call. 2025-09-02 11:45:33.183 | Socket (7) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:33.184 | Historical data download thread signaled to stop. 2025-09-02 11:45:33.184 | HD Request # 13 | Received 265 Daily data records from 2022-01-06 00:00:00 to 2023-01-19 00:00:00 (379.0 days) and wrote 265 records for MCLG23 2025-09-02 11:45:33.184 | HD Request # 13 | Completion time: 1s. 2025-09-02 11:45:33.184 | HD Request # 13 | Daily data download complete for MCLG23. Unique request ID: 12 2025-09-02 11:45:33.184 | Removing historical data download ID 12. 2025-09-02 11:45:33.184 | 2025-09-02 11:45:33.184 | Triggering next historical data download in queue. 2025-09-02 11:45:33.184 | Mapping MCLF23 to MCLF23. Service code: nymex 2025-09-02 11:45:33.184 | HD Request # 14 | Downloading Historical Daily chart data for MCLF23. Starting date: 1923-02-25. Service: nymex 2025-09-02 11:45:33.184 | HD Request # 14 | Using server: ds28.sierracharts.com port 10149 2025-09-02 11:45:33.184 | Socket (11) | Creating socket. 2025-09-02 11:45:33.185 | Socket (11) | New receive buffer size: 5242880 2025-09-02 11:45:33.185 | Socket (11) | Connecting to IP: 67.214.125.5. 2025-09-02 11:45:33.254 | Socket (7) | Socket gracefully closed by remote side. 2025-09-02 11:45:33.254 | Socket (7) | Closed. 2025-09-02 11:45:33.340 | HD Request # 14 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:33.340 | HD Request # 14 | Sending historical data logon request message. 2025-09-02 11:45:33.416 | HD Request # 14 | Requesting historical Daily data starting at 1923-02-25. 2025-09-02 11:45:33.492 | HD Request # 14 | Decompressing data. 2025-09-02 11:45:33.497 | HD Request # 14 | Receiving historical Daily data for MCLF23 starting at 2021-12-06. 2025-09-02 11:45:33.497 | HD Request # 14 | Writing historical Daily data to the file MCLF23.dly. 2025-09-02 11:45:33.504 | Socket (11) | CloseSocket call. 2025-09-02 11:45:33.504 | Socket (11) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:33.505 | Historical data download thread signaled to stop. 2025-09-02 11:45:33.505 | HD Request # 14 | Received 265 Daily data records from 2021-12-06 00:00:00 to 2022-12-19 00:00:00 (379.0 days) and wrote 265 records for MCLF23 2025-09-02 11:45:33.505 | HD Request # 14 | Completion time: 0s. 2025-09-02 11:45:33.505 | HD Request # 14 | Daily data download complete for MCLF23. Unique request ID: 13 2025-09-02 11:45:33.505 | Removing historical data download ID 13. 2025-09-02 11:45:33.505 | 2025-09-02 11:45:33.505 | Triggering next historical data download in queue. 2025-09-02 11:45:33.505 | Mapping MCLZ22 to MCLZ22. Service code: nymex 2025-09-02 11:45:33.505 | HD Request # 15 | Downloading Historical Daily chart data for MCLZ22. Starting date: 1923-01-25. Service: nymex 2025-09-02 11:45:33.505 | HD Request # 15 | Using server: ds26.sierracharts.com port 10150 2025-09-02 11:45:33.505 | Socket (7) | Creating socket. 2025-09-02 11:45:33.505 | Socket (7) | New receive buffer size: 5242880 2025-09-02 11:45:33.505 | Socket (7) | Connecting to IP: 64.152.155.17. 2025-09-02 11:45:33.593 | Socket (11) | Socket gracefully closed by remote side. 2025-09-02 11:45:33.593 | Socket (11) | Closed. 2025-09-02 11:45:33.664 | HD Request # 15 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:33.664 | HD Request # 15 | Sending historical data logon request message. 2025-09-02 11:45:33.740 | HD Request # 15 | Requesting historical Daily data starting at 1923-01-25. 2025-09-02 11:45:33.814 | HD Request # 15 | Decompressing data. 2025-09-02 11:45:33.817 | HD Request # 15 | Receiving historical Daily data for MCLZ22 starting at 2021-07-09. 2025-09-02 11:45:33.818 | HD Request # 15 | Writing historical Daily data to the file MCLZ22.dly. 2025-09-02 11:45:33.827 | Socket (7) | CloseSocket call. 2025-09-02 11:45:33.827 | Socket (7) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:33.828 | Historical data download thread signaled to stop. 2025-09-02 11:45:33.828 | HD Request # 15 | Received 353 Daily data records from 2021-07-09 00:00:00 to 2022-11-18 00:00:00 (498.0 days) and wrote 353 records for MCLZ22 2025-09-02 11:45:33.828 | HD Request # 15 | Completion time: 0s. 2025-09-02 11:45:33.828 | HD Request # 15 | Daily data download complete for MCLZ22. Unique request ID: 14 2025-09-02 11:45:33.828 | Removing historical data download ID 14. 2025-09-02 11:45:33.828 | 2025-09-02 11:45:33.828 | Triggering next historical data download in queue. 2025-09-02 11:45:33.828 | Mapping MCLX22 to MCLX22. Service code: nymex 2025-09-02 11:45:33.828 | HD Request # 16 | Downloading Historical Daily chart data for MCLX22. Starting date: 1922-12-25. Service: nymex 2025-09-02 11:45:33.828 | HD Request # 16 | Using server: ds32.sierracharts.com port 10149 2025-09-02 11:45:33.828 | Socket (11) | Creating socket. 2025-09-02 11:45:33.828 | Socket (11) | New receive buffer size: 5242880 2025-09-02 11:45:33.828 | Socket (11) | Connecting to IP: 69.39.70.248. 2025-09-02 11:45:33.900 | Socket (7) | Socket gracefully closed by remote side. 2025-09-02 11:45:33.900 | Socket (7) | Closed. 2025-09-02 11:45:33.998 | HD Request # 16 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:33.998 | HD Request # 16 | Sending historical data logon request message. 2025-09-02 11:45:34.076 | HD Request # 16 | Requesting historical Daily data starting at 1922-12-25. 2025-09-02 11:45:34.149 | HD Request # 16 | Decompressing data. 2025-09-02 11:45:34.151 | HD Request # 16 | Receiving historical Daily data for MCLX22 starting at 2021-10-06. 2025-09-02 11:45:34.152 | HD Request # 16 | Writing historical Daily data to the file MCLX22.dly. 2025-09-02 11:45:34.156 | Socket (11) | CloseSocket call. 2025-09-02 11:45:34.156 | Socket (11) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:34.156 | Historical data download thread signaled to stop. 2025-09-02 11:45:34.156 | HD Request # 16 | Received 266 Daily data records from 2021-10-06 00:00:00 to 2022-10-19 00:00:00 (379.0 days) and wrote 266 records for MCLX22 2025-09-02 11:45:34.156 | HD Request # 16 | Completion time: 1s. 2025-09-02 11:45:34.156 | HD Request # 16 | Daily data download complete for MCLX22. Unique request ID: 15 2025-09-02 11:45:34.156 | Removing historical data download ID 15. 2025-09-02 11:45:34.156 | 2025-09-02 11:45:34.156 | Triggering next historical data download in queue. 2025-09-02 11:45:34.156 | Mapping MCLV22 to MCLV22. Service code: nymex 2025-09-02 11:45:34.156 | HD Request # 17 | Downloading Historical Daily chart data for MCLV22. Starting date: 1922-11-25. Service: nymex 2025-09-02 11:45:34.156 | HD Request # 17 | Using server: ds28.sierracharts.com port 10150 2025-09-02 11:45:34.156 | Socket (7) | Creating socket. 2025-09-02 11:45:34.157 | Socket (7) | New receive buffer size: 5242880 2025-09-02 11:45:34.157 | Socket (7) | Connecting to IP: 67.214.125.5. 2025-09-02 11:45:34.233 | Socket (11) | Socket gracefully closed by remote side. 2025-09-02 11:45:34.233 | Socket (11) | Closed. 2025-09-02 11:45:34.312 | HD Request # 17 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:34.312 | HD Request # 17 | Sending historical data logon request message. 2025-09-02 11:45:34.418 | HD Request # 17 | Requesting historical Daily data starting at 1922-11-25. 2025-09-02 11:45:34.496 | HD Request # 17 | Decompressing data. 2025-09-02 11:45:34.501 | HD Request # 17 | Receiving historical Daily data for MCLV22 starting at 2021-09-08. 2025-09-02 11:45:34.501 | HD Request # 17 | Writing historical Daily data to the file MCLV22.dly. 2025-09-02 11:45:34.509 | Socket (7) | CloseSocket call. 2025-09-02 11:45:34.509 | Socket (7) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:34.509 | Historical data download thread signaled to stop. 2025-09-02 11:45:34.509 | HD Request # 17 | Received 265 Daily data records from 2021-09-08 00:00:00 to 2022-09-19 00:00:00 (377.0 days) and wrote 265 records for MCLV22 2025-09-02 11:45:34.509 | HD Request # 17 | Completion time: 0s. 2025-09-02 11:45:34.509 | HD Request # 17 | Daily data download complete for MCLV22. Unique request ID: 16 2025-09-02 11:45:34.509 | Removing historical data download ID 16. 2025-09-02 11:45:34.509 | 2025-09-02 11:45:34.509 | Triggering next historical data download in queue. 2025-09-02 11:45:34.509 | Mapping MCLU22 to MCLU22. Service code: nymex 2025-09-02 11:45:34.510 | HD Request # 18 | Downloading Historical Daily chart data for MCLU22. Starting date: 1922-10-25. Service: nymex 2025-09-02 11:45:34.510 | HD Request # 18 | Using server: ds26.sierracharts.com port 10149 2025-09-02 11:45:34.510 | Socket (11) | Creating socket. 2025-09-02 11:45:34.510 | Socket (11) | New receive buffer size: 5242880 2025-09-02 11:45:34.510 | Socket (11) | Connecting to IP: 64.152.155.17. 2025-09-02 11:45:34.598 | Socket (7) | Socket gracefully closed by remote side. 2025-09-02 11:45:34.598 | Socket (7) | Closed. 2025-09-02 11:45:34.669 | HD Request # 18 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:34.669 | HD Request # 18 | Sending historical data logon request message. 2025-09-02 11:45:34.744 | HD Request # 18 | Requesting historical Daily data starting at 1922-10-25. 2025-09-02 11:45:34.823 | HD Request # 18 | Decompressing data. 2025-09-02 11:45:34.825 | HD Request # 18 | Receiving historical Daily data for MCLU22 starting at 2021-08-06. 2025-09-02 11:45:34.825 | HD Request # 18 | Writing historical Daily data to the file MCLU22.dly. 2025-09-02 11:45:34.830 | Socket (11) | CloseSocket call. 2025-09-02 11:45:34.830 | Socket (11) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:34.831 | Historical data download thread signaled to stop. 2025-09-02 11:45:34.831 | HD Request # 18 | Received 267 Daily data records from 2021-08-06 00:00:00 to 2022-08-19 00:00:00 (379.0 days) and wrote 267 records for MCLU22 2025-09-02 11:45:34.831 | HD Request # 18 | Completion time: 0s. 2025-09-02 11:45:34.831 | HD Request # 18 | Daily data download complete for MCLU22. Unique request ID: 17 2025-09-02 11:45:34.831 | Removing historical data download ID 17. 2025-09-02 11:45:34.831 | 2025-09-02 11:45:34.831 | Triggering next historical data download in queue. 2025-09-02 11:45:34.831 | Mapping MCLQ22 to MCLQ22. Service code: nymex 2025-09-02 11:45:34.831 | HD Request # 19 | Downloading Historical Daily chart data for MCLQ22. Starting date: 1922-09-25. Service: nymex 2025-09-02 11:45:34.831 | HD Request # 19 | Using server: ds32.sierracharts.com port 10150 2025-09-02 11:45:34.831 | Socket (7) | Creating socket. 2025-09-02 11:45:34.831 | Socket (7) | New receive buffer size: 5242880 2025-09-02 11:45:34.831 | Socket (7) | Connecting to IP: 69.39.70.248. 2025-09-02 11:45:34.906 | Socket (11) | Socket gracefully closed by remote side. 2025-09-02 11:45:34.906 | Socket (11) | Closed. 2025-09-02 11:45:34.996 | HD Request # 19 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:34.996 | HD Request # 19 | Sending historical data logon request message. 2025-09-02 11:45:35.072 | HD Request # 19 | Requesting historical Daily data starting at 1922-09-25. 2025-09-02 11:45:35.144 | HD Request # 19 | Decompressing data. 2025-09-02 11:45:35.149 | HD Request # 19 | Receiving historical Daily data for MCLQ22 starting at 2021-07-13. 2025-09-02 11:45:35.150 | HD Request # 19 | Writing historical Daily data to the file MCLQ22.dly. 2025-09-02 11:45:35.161 | Socket (7) | CloseSocket call. 2025-09-02 11:45:35.162 | Socket (7) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:35.162 | Historical data download thread signaled to stop. 2025-09-02 11:45:35.162 | HD Request # 19 | Received 261 Daily data records from 2021-07-13 00:00:00 to 2022-07-19 00:00:00 (372.0 days) and wrote 261 records for MCLQ22 2025-09-02 11:45:35.162 | HD Request # 19 | Completion time: 1s. 2025-09-02 11:45:35.162 | HD Request # 19 | Daily data download complete for MCLQ22. Unique request ID: 18 2025-09-02 11:45:35.162 | Removing historical data download ID 18. 2025-09-02 11:45:35.162 | 2025-09-02 11:45:35.162 | Triggering next historical data download in queue. 2025-09-02 11:45:35.162 | Mapping MCLN22 to MCLN22. Service code: nymex 2025-09-02 11:45:35.163 | HD Request # 20 | Downloading Historical Daily chart data for MCLN22. Starting date: 1922-08-25. Service: nymex 2025-09-02 11:45:35.163 | HD Request # 20 | Using server: ds28.sierracharts.com port 10149 2025-09-02 11:45:35.163 | Socket (11) | Creating socket. 2025-09-02 11:45:35.163 | Socket (11) | New receive buffer size: 5242880 2025-09-02 11:45:35.163 | Socket (11) | Connecting to IP: 67.214.125.5. 2025-09-02 11:45:35.241 | Socket (7) | Socket gracefully closed by remote side. 2025-09-02 11:45:35.241 | Socket (7) | Closed. 2025-09-02 11:45:35.330 | HD Request # 20 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:35.330 | HD Request # 20 | Sending historical data logon request message. 2025-09-02 11:45:35.408 | HD Request # 20 | Requesting historical Daily data starting at 1922-08-25. 2025-09-02 11:45:35.482 | HD Request # 20 | Decompressing data. 2025-09-02 11:45:35.486 | HD Request # 20 | Receiving historical Daily data for MCLN22 starting at 2021-07-09. 2025-09-02 11:45:35.486 | HD Request # 20 | Writing historical Daily data to the file MCLN22.dly. 2025-09-02 11:45:35.496 | Socket (11) | CloseSocket call. 2025-09-02 11:45:35.496 | Socket (11) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:35.496 | Historical data download thread signaled to stop. 2025-09-02 11:45:35.496 | HD Request # 20 | Received 242 Daily data records from 2021-07-09 00:00:00 to 2022-06-17 00:00:00 (344.0 days) and wrote 242 records for MCLN22 2025-09-02 11:45:35.496 | HD Request # 20 | Completion time: 0s. 2025-09-02 11:45:35.496 | HD Request # 20 | Daily data download complete for MCLN22. Unique request ID: 19 2025-09-02 11:45:35.496 | Removing historical data download ID 19. 2025-09-02 11:45:35.496 | 2025-09-02 11:45:35.496 | Triggering next historical data download in queue. 2025-09-02 11:45:35.496 | Mapping MCLM22 to MCLM22. Service code: nymex 2025-09-02 11:45:35.497 | HD Request # 21 | Downloading Historical Daily chart data for MCLM22. Starting date: 1922-07-25. Service: nymex 2025-09-02 11:45:35.497 | HD Request # 21 | Using server: ds26.sierracharts.com port 10150 2025-09-02 11:45:35.497 | Socket (7) | Creating socket. 2025-09-02 11:45:35.497 | Socket (7) | New receive buffer size: 5242880 2025-09-02 11:45:35.497 | Socket (7) | Connecting to IP: 64.152.155.17. 2025-09-02 11:45:35.569 | Socket (11) | Socket gracefully closed by remote side. 2025-09-02 11:45:35.569 | Socket (11) | Closed. 2025-09-02 11:45:35.662 | HD Request # 21 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:35.662 | HD Request # 21 | Sending historical data logon request message. 2025-09-02 11:45:35.735 | HD Request # 21 | Requesting historical Daily data starting at 1922-07-25. 2025-09-02 11:45:35.809 | HD Request # 21 | Decompressing data. 2025-09-02 11:45:35.811 | HD Request # 21 | Receiving historical Daily data for MCLM22 starting at 2021-07-09. 2025-09-02 11:45:35.811 | HD Request # 21 | Writing historical Daily data to the file MCLM22.dly. 2025-09-02 11:45:35.818 | Socket (7) | CloseSocket call. 2025-09-02 11:45:35.819 | Socket (7) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:35.823 | Historical data download thread signaled to stop. 2025-09-02 11:45:35.823 | HD Request # 21 | Received 222 Daily data records from 2021-07-09 00:00:00 to 2022-05-19 00:00:00 (315.0 days) and wrote 222 records for MCLM22 2025-09-02 11:45:35.823 | HD Request # 21 | Completion time: 0s. 2025-09-02 11:45:35.823 | HD Request # 21 | Daily data download complete for MCLM22. Unique request ID: 20 2025-09-02 11:45:35.823 | Removing historical data download ID 20. 2025-09-02 11:45:35.823 | 2025-09-02 11:45:35.823 | Triggering next historical data download in queue. 2025-09-02 11:45:35.823 | Mapping MCLK22 to MCLK22. Service code: nymex 2025-09-02 11:45:35.823 | HD Request # 22 | Downloading Historical Daily chart data for MCLK22. Starting date: 1922-06-25. Service: nymex 2025-09-02 11:45:35.823 | HD Request # 22 | Using server: ds32.sierracharts.com port 10149 2025-09-02 11:45:35.823 | Socket (11) | Creating socket. 2025-09-02 11:45:35.824 | Socket (11) | New receive buffer size: 5242880 2025-09-02 11:45:35.824 | Socket (11) | Connecting to IP: 69.39.70.248. 2025-09-02 11:45:35.894 | Socket (7) | Socket gracefully closed by remote side. 2025-09-02 11:45:35.895 | Socket (7) | Closed. 2025-09-02 11:45:35.992 | HD Request # 22 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:35.992 | HD Request # 22 | Sending historical data logon request message. 2025-09-02 11:45:36.068 | HD Request # 22 | Requesting historical Daily data starting at 1922-06-25. 2025-09-02 11:45:36.148 | HD Request # 22 | Decompressing data. 2025-09-02 11:45:36.151 | HD Request # 22 | Receiving historical Daily data for MCLK22 starting at 2021-07-09. 2025-09-02 11:45:36.151 | HD Request # 22 | Writing historical Daily data to the file MCLK22.dly. 2025-09-02 11:45:36.155 | Socket (11) | CloseSocket call. 2025-09-02 11:45:36.155 | Socket (11) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:36.155 | Historical data download thread signaled to stop. 2025-09-02 11:45:36.155 | HD Request # 22 | Received 200 Daily data records from 2021-07-09 00:00:00 to 2022-04-19 00:00:00 (285.0 days) and wrote 200 records for MCLK22 2025-09-02 11:45:36.155 | HD Request # 22 | Completion time: 1s. 2025-09-02 11:45:36.155 | HD Request # 22 | Daily data download complete for MCLK22. Unique request ID: 21 2025-09-02 11:45:36.155 | Removing historical data download ID 21. 2025-09-02 11:45:36.155 | 2025-09-02 11:45:36.155 | Triggering next historical data download in queue. 2025-09-02 11:45:36.155 | Mapping MCLJ22 to MCLJ22. Service code: nymex 2025-09-02 11:45:36.156 | HD Request # 23 | Downloading Historical Daily chart data for MCLJ22. Starting date: 1922-05-25. Service: nymex 2025-09-02 11:45:36.156 | HD Request # 23 | Using server: ds28.sierracharts.com port 10150 2025-09-02 11:45:36.156 | Socket (7) | Creating socket. 2025-09-02 11:45:36.156 | Socket (7) | New receive buffer size: 5242880 2025-09-02 11:45:36.156 | Socket (7) | Connecting to IP: 67.214.125.5. 2025-09-02 11:45:36.225 | Socket (11) | Socket gracefully closed by remote side. 2025-09-02 11:45:36.225 | Socket (11) | Closed. 2025-09-02 11:45:36.312 | HD Request # 23 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:36.312 | HD Request # 23 | Sending historical data logon request message. 2025-09-02 11:45:36.384 | HD Request # 23 | Requesting historical Daily data starting at 1922-05-25. 2025-09-02 11:45:36.454 | HD Request # 23 | Decompressing data. 2025-09-02 11:45:36.459 | HD Request # 23 | Receiving historical Daily data for MCLJ22 starting at 2021-07-09. 2025-09-02 11:45:36.460 | HD Request # 23 | Writing historical Daily data to the file MCLJ22.dly. 2025-09-02 11:45:36.468 | Socket (7) | CloseSocket call. 2025-09-02 11:45:36.468 | Socket (7) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:36.474 | Historical data download thread signaled to stop. 2025-09-02 11:45:36.474 | HD Request # 23 | Received 180 Daily data records from 2021-07-09 00:00:00 to 2022-03-21 00:00:00 (256.0 days) and wrote 180 records for MCLJ22 2025-09-02 11:45:36.474 | HD Request # 23 | Completion time: 0s. 2025-09-02 11:45:36.474 | HD Request # 23 | Daily data download complete for MCLJ22. Unique request ID: 22 2025-09-02 11:45:36.474 | Removing historical data download ID 22. 2025-09-02 11:45:36.474 | 2025-09-02 11:45:36.474 | Triggering next historical data download in queue. 2025-09-02 11:45:36.474 | Mapping MCLH22 to MCLH22. Service code: nymex 2025-09-02 11:45:36.475 | HD Request # 24 | Downloading Historical Daily chart data for MCLH22. Starting date: 1922-04-25. Service: nymex 2025-09-02 11:45:36.475 | HD Request # 24 | Using server: ds26.sierracharts.com port 10149 2025-09-02 11:45:36.475 | Socket (11) | Creating socket. 2025-09-02 11:45:36.476 | Socket (11) | New receive buffer size: 5242880 2025-09-02 11:45:36.476 | Socket (11) | Connecting to IP: 64.152.155.17. 2025-09-02 11:45:36.545 | Socket (7) | Socket gracefully closed by remote side. 2025-09-02 11:45:36.545 | Socket (7) | Closed. 2025-09-02 11:45:36.642 | HD Request # 24 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:36.642 | HD Request # 24 | Sending historical data logon request message. 2025-09-02 11:45:36.717 | HD Request # 24 | Requesting historical Daily data starting at 1922-04-25. 2025-09-02 11:45:36.792 | HD Request # 24 | Decompressing data. 2025-09-02 11:45:36.795 | HD Request # 24 | Receiving historical Daily data for MCLH22 starting at 2021-07-09. 2025-09-02 11:45:36.796 | HD Request # 24 | Writing historical Daily data to the file MCLH22.dly. 2025-09-02 11:45:36.804 | Socket (11) | CloseSocket call. 2025-09-02 11:45:36.805 | Socket (11) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:36.805 | Historical data download thread signaled to stop. 2025-09-02 11:45:36.805 | HD Request # 24 | Received 160 Daily data records from 2021-07-09 00:00:00 to 2022-02-18 00:00:00 (225.0 days) and wrote 160 records for MCLH22 2025-09-02 11:45:36.805 | HD Request # 24 | Completion time: 0s. 2025-09-02 11:45:36.805 | HD Request # 24 | Daily data download complete for MCLH22. Unique request ID: 23 2025-09-02 11:45:36.805 | Removing historical data download ID 23. 2025-09-02 11:45:36.805 | 2025-09-02 11:45:36.806 | Triggering next historical data download in queue. 2025-09-02 11:45:36.806 | Mapping MCLG22 to MCLG22. Service code: nymex 2025-09-02 11:45:36.806 | HD Request # 25 | Downloading Historical Daily chart data for MCLG22. Starting date: 1922-03-25. Service: nymex 2025-09-02 11:45:36.807 | HD Request # 25 | Using server: ds32.sierracharts.com port 10150 2025-09-02 11:45:36.807 | Socket (7) | Creating socket. 2025-09-02 11:45:36.807 | Socket (7) | New receive buffer size: 5242880 2025-09-02 11:45:36.807 | Socket (7) | Connecting to IP: 69.39.70.248. 2025-09-02 11:45:36.881 | Socket (11) | Socket gracefully closed by remote side. 2025-09-02 11:45:36.881 | Socket (11) | Closed. 2025-09-02 11:45:36.994 | HD Request # 25 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:36.994 | HD Request # 25 | Sending historical data logon request message. 2025-09-02 11:45:37.070 | HD Request # 25 | Requesting historical Daily data starting at 1922-03-25. 2025-09-02 11:45:37.140 | HD Request # 25 | Decompressing data. 2025-09-02 11:45:37.144 | HD Request # 25 | Receiving historical Daily data for MCLG22 starting at 2021-07-09. 2025-09-02 11:45:37.145 | HD Request # 25 | Writing historical Daily data to the file MCLG22.dly. 2025-09-02 11:45:37.152 | Socket (7) | CloseSocket call. 2025-09-02 11:45:37.152 | Socket (7) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:37.155 | Historical data download thread signaled to stop. 2025-09-02 11:45:37.155 | HD Request # 25 | Received 138 Daily data records from 2021-07-09 00:00:00 to 2022-01-19 00:00:00 (195.0 days) and wrote 138 records for MCLG22 2025-09-02 11:45:37.155 | HD Request # 25 | Completion time: 1s. 2025-09-02 11:45:37.155 | HD Request # 25 | Daily data download complete for MCLG22. Unique request ID: 24 2025-09-02 11:45:37.155 | Removing historical data download ID 24. 2025-09-02 11:45:37.155 | 2025-09-02 11:45:37.155 | Triggering next historical data download in queue. 2025-09-02 11:45:37.155 | Mapping MCLF22 to MCLF22. Service code: nymex 2025-09-02 11:45:37.156 | HD Request # 26 | Downloading Historical Daily chart data for MCLF22. Starting date: 1922-02-25. Service: nymex 2025-09-02 11:45:37.156 | HD Request # 26 | Using server: ds28.sierracharts.com port 10149 2025-09-02 11:45:37.156 | Socket (11) | Creating socket. 2025-09-02 11:45:37.157 | Socket (11) | New receive buffer size: 5242880 2025-09-02 11:45:37.157 | Socket (11) | Connecting to IP: 67.214.125.5. 2025-09-02 11:45:37.226 | Socket (7) | Socket gracefully closed by remote side. 2025-09-02 11:45:37.226 | Socket (7) | Closed. 2025-09-02 11:45:37.310 | HD Request # 26 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:37.310 | HD Request # 26 | Sending historical data logon request message. 2025-09-02 11:45:37.385 | HD Request # 26 | Requesting historical Daily data starting at 1922-02-25. 2025-09-02 11:45:37.461 | HD Request # 26 | Decompressing data. 2025-09-02 11:45:37.462 | HD Request # 26 | Receiving historical Daily data for MCLF22 starting at 2021-07-09. 2025-09-02 11:45:37.463 | HD Request # 26 | Writing historical Daily data to the file MCLF22.dly. 2025-09-02 11:45:37.468 | Socket (11) | CloseSocket call. 2025-09-02 11:45:37.468 | Socket (11) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:37.471 | Historical data download thread signaled to stop. 2025-09-02 11:45:37.471 | HD Request # 26 | Received 116 Daily data records from 2021-07-09 00:00:00 to 2021-12-17 00:00:00 (162.0 days) and wrote 116 records for MCLF22 2025-09-02 11:45:37.471 | HD Request # 26 | Completion time: 0s. 2025-09-02 11:45:37.471 | HD Request # 26 | Daily data download complete for MCLF22. Unique request ID: 25 2025-09-02 11:45:37.471 | Removing historical data download ID 25. 2025-09-02 11:45:37.471 | 2025-09-02 11:45:37.471 | Triggering next historical data download in queue. 2025-09-02 11:45:37.471 | Mapping MCLZ21 to MCLZ21. Service code: nymex 2025-09-02 11:45:37.471 | HD Request # 27 | Downloading Historical Daily chart data for MCLZ21. Starting date: 1922-01-25. Service: nymex 2025-09-02 11:45:37.472 | HD Request # 27 | Using server: ds26.sierracharts.com port 10150 2025-09-02 11:45:37.472 | Socket (7) | Creating socket. 2025-09-02 11:45:37.472 | Socket (7) | New receive buffer size: 5242880 2025-09-02 11:45:37.472 | Socket (7) | Connecting to IP: 64.152.155.17. 2025-09-02 11:45:37.545 | Socket (11) | Socket gracefully closed by remote side. 2025-09-02 11:45:37.545 | Socket (11) | Closed. 2025-09-02 11:45:37.629 | HD Request # 27 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:37.629 | HD Request # 27 | Sending historical data logon request message. 2025-09-02 11:45:37.713 | HD Request # 27 | Requesting historical Daily data starting at 1922-01-25. 2025-09-02 11:45:37.809 | HD Request # 27 | Decompressing data. 2025-09-02 11:45:37.812 | HD Request # 27 | Receiving historical Daily data for MCLZ21 starting at 2021-07-09. 2025-09-02 11:45:37.813 | HD Request # 27 | Writing historical Daily data to the file MCLZ21.dly. 2025-09-02 11:45:37.819 | Socket (7) | CloseSocket call. 2025-09-02 11:45:37.819 | Socket (7) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:37.820 | Historical data download thread signaled to stop. 2025-09-02 11:45:37.820 | HD Request # 27 | Received 95 Daily data records from 2021-07-09 00:00:00 to 2021-11-18 00:00:00 (133.0 days) and wrote 95 records for MCLZ21 2025-09-02 11:45:37.820 | HD Request # 27 | Completion time: 0s. 2025-09-02 11:45:37.820 | HD Request # 27 | Daily data download complete for MCLZ21. Unique request ID: 26 2025-09-02 11:45:37.820 | Removing historical data download ID 26. 2025-09-02 11:45:37.820 | 2025-09-02 11:45:37.820 | Triggering next historical data download in queue. 2025-09-02 11:45:37.821 | Mapping MCLX21 to MCLX21. Service code: nymex 2025-09-02 11:45:37.821 | HD Request # 28 | Downloading Historical Daily chart data for MCLX21. Starting date: 1921-12-25. Service: nymex 2025-09-02 11:45:37.821 | HD Request # 28 | Using server: ds32.sierracharts.com port 10149 2025-09-02 11:45:37.821 | Socket (11) | Creating socket. 2025-09-02 11:45:37.822 | Socket (11) | New receive buffer size: 5242880 2025-09-02 11:45:37.822 | Socket (11) | Connecting to IP: 69.39.70.248. 2025-09-02 11:45:37.893 | Socket (7) | Socket gracefully closed by remote side. 2025-09-02 11:45:37.893 | Socket (7) | Closed. 2025-09-02 11:45:37.980 | HD Request # 28 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:37.980 | HD Request # 28 | Sending historical data logon request message. 2025-09-02 11:45:38.053 | HD Request # 28 | Requesting historical Daily data starting at 1921-12-25. 2025-09-02 11:45:38.124 | HD Request # 28 | Decompressing data. 2025-09-02 11:45:38.126 | HD Request # 28 | Receiving historical Daily data for MCLX21 starting at 2021-07-09. 2025-09-02 11:45:38.126 | HD Request # 28 | Writing historical Daily data to the file MCLX21.dly. 2025-09-02 11:45:38.128 | Socket (11) | CloseSocket call. 2025-09-02 11:45:38.129 | Socket (11) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:38.132 | Historical data download thread signaled to stop. 2025-09-02 11:45:38.132 | HD Request # 28 | Received 73 Daily data records from 2021-07-09 00:00:00 to 2021-10-19 00:00:00 (103.0 days) and wrote 73 records for MCLX21 2025-09-02 11:45:38.132 | HD Request # 28 | Completion time: 1s. 2025-09-02 11:45:38.132 | HD Request # 28 | Daily data download complete for MCLX21. Unique request ID: 27 2025-09-02 11:45:38.132 | Removing historical data download ID 27. 2025-09-02 11:45:38.132 | 2025-09-02 11:45:38.132 | Triggering next historical data download in queue. 2025-09-02 11:45:38.132 | Mapping MCLV21 to MCLV21. Service code: nymex 2025-09-02 11:45:38.132 | HD Request # 29 | Downloading Historical Daily chart data for MCLV21. Starting date: 1921-11-25. Service: nymex 2025-09-02 11:45:38.133 | HD Request # 29 | Using server: ds28.sierracharts.com port 10150 2025-09-02 11:45:38.133 | Socket (7) | Creating socket. 2025-09-02 11:45:38.133 | Socket (7) | New receive buffer size: 5242880 2025-09-02 11:45:38.133 | Socket (7) | Connecting to IP: 67.214.125.5. 2025-09-02 11:45:38.206 | Socket (11) | Socket gracefully closed by remote side. 2025-09-02 11:45:38.206 | Socket (11) | Closed. 2025-09-02 11:45:38.292 | HD Request # 29 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:38.292 | HD Request # 29 | Sending historical data logon request message. 2025-09-02 11:45:38.371 | HD Request # 29 | Requesting historical Daily data starting at 1921-11-25. 2025-09-02 11:45:38.446 | HD Request # 29 | Decompressing data. 2025-09-02 11:45:38.447 | HD Request # 29 | Receiving historical Daily data for MCLV21 starting at 2021-07-09. 2025-09-02 11:45:38.447 | HD Request # 29 | Writing historical Daily data to the file MCLV21.dly. 2025-09-02 11:45:38.451 | Socket (7) | CloseSocket call. 2025-09-02 11:45:38.451 | Socket (7) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:38.455 | Historical data download thread signaled to stop. 2025-09-02 11:45:38.455 | HD Request # 29 | Received 52 Daily data records from 2021-07-09 00:00:00 to 2021-09-20 00:00:00 (74.0 days) and wrote 52 records for MCLV21 2025-09-02 11:45:38.455 | HD Request # 29 | Completion time: 0s. 2025-09-02 11:45:38.455 | HD Request # 29 | Daily data download complete for MCLV21. Unique request ID: 28 2025-09-02 11:45:38.455 | Removing historical data download ID 28. 2025-09-02 11:45:38.456 | 2025-09-02 11:45:38.456 | Triggering next historical data download in queue. 2025-09-02 11:45:38.456 | Mapping MCLU21 to MCLU21. Service code: nymex 2025-09-02 11:45:38.456 | HD Request # 30 | Downloading Historical Daily chart data for MCLU21. Starting date: 1921-10-25. Service: nymex 2025-09-02 11:45:38.456 | HD Request # 30 | Using server: ds26.sierracharts.com port 10149 2025-09-02 11:45:38.457 | Socket (11) | Creating socket. 2025-09-02 11:45:38.457 | Socket (11) | New receive buffer size: 5242880 2025-09-02 11:45:38.457 | Socket (11) | Connecting to IP: 64.152.155.17. 2025-09-02 11:45:38.527 | Socket (7) | Socket gracefully closed by remote side. 2025-09-02 11:45:38.528 | Socket (7) | Closed. 2025-09-02 11:45:38.624 | HD Request # 30 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:38.624 | HD Request # 30 | Sending historical data logon request message. 2025-09-02 11:45:38.699 | HD Request # 30 | Requesting historical Daily data starting at 1921-10-25. 2025-09-02 11:45:38.774 | HD Request # 30 | Decompressing data. 2025-09-02 11:45:38.775 | HD Request # 30 | Receiving historical Daily data for MCLU21 starting at 2021-07-09. 2025-09-02 11:45:38.776 | HD Request # 30 | Writing historical Daily data to the file MCLU21.dly. 2025-09-02 11:45:38.777 | Socket (11) | CloseSocket call. 2025-09-02 11:45:38.777 | Socket (11) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:38.783 | Historical data download thread signaled to stop. 2025-09-02 11:45:38.783 | HD Request # 30 | Received 30 Daily data records from 2021-07-09 00:00:00 to 2021-08-19 00:00:00 (42.0 days) and wrote 30 records for MCLU21 2025-09-02 11:45:38.783 | HD Request # 30 | Completion time: 0s. 2025-09-02 11:45:38.783 | HD Request # 30 | Daily data download complete for MCLU21. Unique request ID: 29 2025-09-02 11:45:38.783 | Removing historical data download ID 29. 2025-09-02 11:45:38.783 | 2025-09-02 11:45:38.783 | Triggering next historical data download in queue. 2025-09-02 11:45:38.783 | HD Request # 31 | Downloading Historical Daily chart data for MCLQ21. Starting date: 1921-09-25. Service: nymex 2025-09-02 11:45:38.783 | HD Request # 31 | Using server: ds32.sierracharts.com port 10150 2025-09-02 11:45:38.784 | Socket (7) | Creating socket. 2025-09-02 11:45:38.784 | Socket (7) | New receive buffer size: 5242880 2025-09-02 11:45:38.784 | Socket (7) | Connecting to IP: 69.39.70.248. 2025-09-02 11:45:38.850 | Socket (11) | Socket gracefully closed by remote side. 2025-09-02 11:45:38.850 | Socket (11) | Closed. 2025-09-02 11:45:38.944 | HD Request # 31 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:38.944 | HD Request # 31 | Sending historical data logon request message. 2025-09-02 11:45:39.018 | HD Request # 31 | Requesting historical Daily data starting at 1921-09-25. 2025-09-02 11:45:39.088 | HD Request # 31 | Decompressing data. 2025-09-02 11:45:39.090 | HD Request # 31 | Receiving historical Daily data for MCLQ21 starting at 2021-07-09. 2025-09-02 11:45:39.090 | HD Request # 31 | Writing historical Daily data to the file MCLQ21.dly. 2025-09-02 11:45:39.091 | Socket (7) | CloseSocket call. 2025-09-02 11:45:39.091 | Socket (7) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:39.091 | Historical data download thread signaled to stop. 2025-09-02 11:45:39.091 | HD Request # 31 | Received 7 Daily data records from 2021-07-09 00:00:00 to 2021-07-19 00:00:00 (11.0 days) and wrote 7 records for MCLQ21 2025-09-02 11:45:39.091 | HD Request # 31 | Completion time: 1s. 2025-09-02 11:45:39.091 | HD Request # 31 | Daily data download complete for MCLQ21. Unique request ID: 30 2025-09-02 11:45:39.091 | Removing historical data download ID 30. 2025-09-02 11:45:39.091 | 2025-09-02 11:45:39.091 | Triggering next historical data download in queue. 2025-09-02 11:45:39.091 | Mapping MCLN21 to MCLN21. Service code: nymex 2025-09-02 11:45:39.092 | HD Request # 32 | Downloading Historical Daily chart data for MCLN21. Starting date: 1921-08-25. Service: nymex 2025-09-02 11:45:39.092 | HD Request # 32 | Using server: ds28.sierracharts.com port 10149 2025-09-02 11:45:39.092 | Socket (11) | Creating socket. 2025-09-02 11:45:39.092 | Socket (11) | New receive buffer size: 5242880 2025-09-02 11:45:39.092 | Socket (11) | Connecting to IP: 67.214.125.5. 2025-09-02 11:45:39.164 | Socket (7) | Socket gracefully closed by remote side. 2025-09-02 11:45:39.164 | Socket (7) | Closed. 2025-09-02 11:45:39.248 | HD Request # 32 | Setting DTC encoding to Binary VLS 2025-09-02 11:45:39.248 | HD Request # 32 | Sending historical data logon request message. 2025-09-02 11:45:39.324 | HD Request # 32 | Requesting historical Daily data starting at 1921-08-25. 2025-09-02 11:45:39.399 | Socket (11) | CloseSocket call. 2025-09-02 11:45:39.399 | Socket (11) | Shutdown started. Waiting for graceful close. 2025-09-02 11:45:39.400 | HD Request # 32 | Error downloading historical Daily data for MCLN21. Historical data file for MCLN21 not available. 2025-09-02 11:45:39.400 | Historical data download thread signaled to stop. 2025-09-02 11:45:39.400 | HD Request # 32 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MCLN21 2025-09-02 11:45:39.400 | HD Request # 32 | Completion time: 0s. 2025-09-02 11:45:39.400 | HD Request # 32 | Daily data download complete for MCLN21. Unique request ID: 31 2025-09-02 11:45:39.400 | Removing historical data download ID 31. 2025-09-02 11:45:39.400 | 2025-09-02 11:45:39.400 | Triggering next historical data download in queue. 2025-09-02 11:45:39.401 | Mapping MNGZ23 to MNGZ23. Service code: nymex 2025-09-02 11:45:39.401 | HD Request # 33 | Downloading Intraday chart data for MNGZ23 to the file MNGZ23.scid. Service: nymex 2025-09-02 11:45:39.401 | File compression not supported on file system. C:\ProgramData\SierraChart\Data\MNGZ23.scid. Windows error code 50: Request not supported. 2025-09-02 11:45:39.402 | HD Request # 33 | Download start date-time: 2023-10-03 17:00:00.000000. File last date-time: 2023-11-27 11:26:24.167000 2025-09-02 11:45:39.402 | HD Request # 33 | Disabling Intraday chart updating for symbol. 2025-09-02 11:45:39.402 | HD Request # 33 | Using server: ds26.sierracharts.com port 10150 2025-09-02 11:45:39.402 | Socket (7) | Creating socket. 2025-09-02 11:45:39.402 | Socket (7) | New receive buffer size: 5242880 2025-09-02 11:45:39.402 | Socket (7) | Connecting to IP: 64.152.155.17. 2025-09-02 11:45:39.470 | Socket (11) | Socket gracefully closed by remote side. 2025-09-02 11:45:39.470 | Socket (11) | Closed. |
| [2025-09-02 21:08:29] |
| Sierra_Chart Engineering - Posts: 25481 |
This is totally irrelevant and a complete non-issue. It has no impact at all on anything: but when I restart sierra I still see logs requesting data from 1923, 1922, etc. on startup.
We will not say anything further on this. It is meaningless.
Am I still doing something wrong? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-11 20:07:37] |
Not true. It should not be requesting data, I think we are agreeing there. Maybe it is not requesting data, I can't tell, but the logs are contradictory if so. But it is undeniable that while the logs print that it is requesting the data, the charts are stuck in a loading state until the logs finish. So it is not without any side effects. I don't care if you fix it at this point but I'm saying what it is. |
| [2025-09-11 20:27:55] |
1. My MCL intraday and historical daily data is fully downloaded. 2. I have the MCL chart open as an intraday 24 hour chart. 3. I leave my computer on for ~10 hours. 4. I Reload & Recalculate the MCL chart. From all the info you've given me this does not trigger a redownload. There is no missing data because it was already fully downloaded. The logs show requesting data from 1900s. They are not real requests, fine. But the chart screen is blank with a loading bar while these "fake requests" are written to the log, taking ~30 seconds. As soon as the log is finished, the chart appears. totally irrelevant and a complete non-issue. It has no impact at all on anything:
Untrue.
| [2025-09-11 22:23:27] |
We meant to follow-up in this thread. The actual starting date of a historical daily download is not relevant. Once again we are reaffirming: totally irrelevant and a complete non-issue. It has no impact at all on anything:
It should not be requesting data, I think we are agreeing there. However, there should not be any historical data download requests, for expired futures contracts if the data has already been downloaded. This is the issue and this is what we meant to follow up with. But this is fully unrelated, to the starting date of the download. Completely unrelated. We want you to attach to this thread that MCL chart. Instructions: https://www8.sierrachart.com/index.php?page=doc/PostingInformation.php#ProvidingChartbookSingleChart They are real historical data requests, and should not be happening again and again for expired future contracts: The logs show requesting data from 1900s. They are not real requests, fine.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-09-11 22:25:09
| [2025-09-11 23:33:29] |
I've described multiple times in this thread that the requests for 1900s data happens after a full data download in which it shouldn't be happening; I don't know how I could be any clearer. The starting date may be irrelevant from your perspective but the logs should not be there as you've just confirmed, and discussing the technicalities of an implementation detail that I shouldn't be repeatedly seeing is only confusing. Glad we can move on to the real issue. Since they are real requests, that is problematic, as that contributes to my monthly limit. |
| [2025-09-11 23:42:57] |
Don't know if it's relevant but in case it is, I'm on Trading Evaluator - Delayed
| [2025-09-16 14:12:47] |
Thank you we will be testing this. And see what the problem is.
| [2025-09-24 20:15:13] |
We have worked on this issue. Do the following: 1. Update Sierra Chart to the latest prerelease: Software Download: Fast Update 2. The earliest date we want you to load for MCL should be 2022-1-1 3. Update the symbol settings: Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-09-24 20:15:29
| [2025-09-24 22:12:56] |
That seems to fix it, thanks. Finally, can I please get 1 week credited for my account? My usage was cut short for 1 week at the end of August because of all the extra downloads causing the historical daily data download limit to be exceeded. |
| [2025-09-25 01:35:54] |
We have added a time credit to your account.
