Date/Time: Wed, 25 Nov 2026 07:55:56 +0000
Auto Trade System Replay Back Test
View Count: 975
| [2025-08-23 19:37:01] |
| Tin43 - Posts: 164 |
I want to backtest a strategy I designed. I set to Auto Trade System Replay Back Test with Accurate Trade System Back Test Mode. I set speed to 200000X. But it took like 10 minutes to process 1 day. I got only RTH, no weekends, Skip empty periods. I don't know what to do or wha ti'm missing to set the test to go faster. I would appreciate any information. (Apologies for my English). |
| [2025-08-25 16:03:43] |
| John - SC Support - Posts: 48648 |
The amount of time sounds about right for what you are doing. Refer to the following for some items that can be looked into to increase performance: Auto Trade System Back Testing: Improving Back Test Performance For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-02 09:23:53] |
Hi... It is possible to decide a range of hours to load on the chart? For example... imagine i only want the time range from 9:30 to 11. Could I load future contract chart with that time range only? Like when you could mark "Load weekend data bla bla..." or something like that. That you can select Yes or No. If not.. could it be an implementation in the future? |
| [2025-09-02 14:42:31] |
You can do what you want by setting the Session Times. Refer to the following: Chart Session Times For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
