Date/Time: Sat, 27 Apr 2024 23:56:07 +0000
[User Discussion] - Spreadsheet Study
View Count: 875
[2014-10-09 13:05:51] |
User16114 - Posts: 153 |
In a custom spreadsheet study I am using "Cumulative Sum of Study" on the "Volume" study for the ES and the "Cumulative Sum of Study" is outputted to spreadsheet column AD. Then, I am using column AD data in a formula in column K which I think is causing an issue with calculation precedence. 1. Is there a way to get "Cumulative Sum of Study" outputted in column K or to the left of L? Or 2. Is there a way to output column AD from one spreadsheet to column K in a second spreadsheet? Thanks! |
[2014-10-09 13:27:08] |
Sawtooth - Posts: 3980 |
1) You can use =AD3 in K3. 2) This is possible, but not in the New Spreadsheets versions. However, you probably don't need to do resort to this solution. |
