Date/Time: Wed, 25 Nov 2026 16:03:23 +0000
Multi-Ticker Screen
View Count: 608
[2025-08-22 22:53:51]
cmack1011 - Posts: 201
Can you please direct me to information on how best to set up and manage a multi-chart window for visually tracking many different tickers at the same time? I know how to set up a "Tile as Grid" window, but what is the best way to control each chart from one control panel/watchlist assuming that each chart has a different ticker symbol?
Date Time Of Last Edit: 2025-08-23 11:30:41
[2025-08-25 12:53:57]
Sierra_Chart Engineering - Posts: 25481
Use this study:
Add Additional Symbol
Date Time Of Last Edit: 2025-08-25 12:54:02
[2025-08-25 13:55:12]
Thank you for response.
I understand that the "Add Additonal Symbol" study will add another ticker to the same chart, but what I am trying to do is track the price (using candlesticks) and volume and MACD for multiple tickers, which I assume is going to require a separate chart for each ticker? Can you tell me what is the best "set-up" to do this? I already have a tile grid of 8 candle stick charts, each with a different ticker and each showing price, volume, MACD. Is there a way to create a single control panel/watchlist to control each chart individually or all at the same time, etc? Is there a "best way" to set this up where you can do things like change out a ticker symbol or change a time frame or study using only one control panel? Or do I have to go into each chart individually to make changes? Thx!
[2025-08-25 14:06:31]
Yes:
If there are settings that you want to change across all charts at once when controlling a single chart, you can use Chart Linking:
Working With Charts: Chart Linking
[2025-08-25 14:52:34]
Ok
IS there a way to implement a chart watchlist scrolling feature where the platform will automatically scroll through the charts of the tickers in your watchlist?
[2025-08-25 16:18:55]
No this is not supported.
