Date/Time: Wed, 25 Nov 2026 16:03:18 +0000
Regarding custom drawing configuration.
View Count: 542
[2025-08-22 04:18:14]
ArmaanSingh - Posts: 23
hi,
I want to have a custom drawing configuration for the extended rectangle tool. But I dont know how to do it, just know that it would be after opening chart drawing properties option after right click the tool.
so can you guys please tell me how to do that, it would really help me
[2025-08-22 12:54:11]
TonyCipriani - Posts: 155
Go to Properties of that tool > Customize it how you like > Go to 'Config' menu on top > Scroll down to 'Tool Configuration (List)' > Use 'TC1' to make it default > Press the (Button) where it says [Save] > Apply
[2025-08-22 14:36:50]
Refer to the following:
Chart Drawing Tools: Drawing Tool Configuration
Chart Drawing Tools: Using Multiple Drawing Tool Configurations
