Date/Time: Wed, 25 Nov 2026 07:55:47 +0000
It is possible to enable multiple alert at the same time ?
View Count: 506
| [2025-08-21 14:21:55] |
| GravisHTG - Posts: 321 |
I am buildind an audio alert system that trigger base on bid/ask flow. And after looking at it - I can make it work , but It can only play the alert in a Queue. Sometimes I can get 5-6 alert in 1 sec , when the market is very fast. So I wonder if its possible to enable multiple alert at the same time ? thanks in advance |
| [2025-08-21 15:36:46] |
| John - SC Support - Posts: 48648 |
Refer to the following setting: General Settings Window: Wait for Prior Alert Sound to Finish Before Playing Next Queued Sound (Global Settings >> General Settings >> Alerts >> Additional Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-21 16:13:22] |
Can it play one of top of the other , with no waiting ?
| [2025-08-21 17:57:45] |
If you set the option we referenced to "No", then that is what is supposed to occur.
| [2025-08-28 21:20:55] |
after I put Wait for prior Alert Sound to finish before playing Next queued sound to no Its still putting a Queue - Its doing Tac - Tac - Tac - Tac - Tac - Bong -Tac Tac instead of a fast - TTTTTaBoTTac and its still going even after the action end. when their is no more alert comming in. Alert hit everytime their is a 10 consecutive Ask or Bid volume. if you want the context of it. Is that because they come from the same study ? and thanks again for your help Date Time Of Last Edit: 2025-08-28 21:23:05
| [2025-09-02 23:22:03] |
| Sierra_Chart Engineering - Posts: 25479 |
We are not able to help further with this.
