Date/Time: Tue, 24 Nov 2026 18:17:01 +0000
MBT on CME shows as delayed even though running through Teton and live data service.
View Count: 630
| [2025-08-21 13:29:26] |
| User694867 - Posts: 9 |
Hi, I hope you are well. So I recently auto rolled over MBT using, Chart Settings -> Symbols -> Auto Roll Futures Symbol. This has been done many times with no issue and on a variety of different symbols. Though for some reason MBT has decided to bring up a Delayed symbol (CBV-D) though appears to not actually be delayed, i.e. no time lag or maybe 100ms - fine. The issue being though for example the Daily candles now only go back to circa Feb'25 and approx. 40% are just a horizontal line being the candle and no volume or a miniscule value - which is clearly not the case. I have been getting screen grab from Jul'25 showing clearly there is something, which therefore leads me to question is the Market Profile or Footprint correct. Please see the attached images and note the discrepancy from circa Apr'25 going back in time and also the top RHS where there is [CBV][M] Vs. [CVB-D][M]. This appears has just purely resulted from a contract rollover as previously mentioned, please note I have tried to change the contract moving it back moving forward and it still stays the same. Basically the image from July clearly shows there is an issue with what is currently being displayed. Please note I have symbols of other contracts that do not show as delayed running at the same time. Please advise, thank you. |
Private File Private File |
| [2025-08-21 15:35:37] |
| John - SC Support - Posts: 48643 |
The notation of [CBV-D] does not mean "delayed". It means that the Continuous Futures Contract option is disabled. Refer to the following for the information on that notation: Continuous Futures Contract Charts: Text Indicator Description Table This particular issue is fixed in a current release, so please update by following these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
