Date/Time: Wed, 25 Nov 2026 16:03:17 +0000
Issues with P/L display and average open position line - Interactive Brokers
View Count: 474
[2025-08-21 11:14:33]
maxm1987 - Posts: 136
Hello there,
I know that there are functional issues with Interactive Brokers, so if there is no easy fix it is alright, just wanted to ask anyway.
1. Concerning P/L display: as you can see in the screenshot i opened a position with 1 mnq that went a little bit against me. However, the P/L in the trade window doesnt show anything. Is there a fix for that? (here I may also add that the DPL number is way off from the actual number in the trader work station that does reflect the correct number
2. Second, whenever I open a position the line, that indicates the average position price only appears for half a second and then disappears. Is this a common issue?
imageIB.png / V - Attached On 2025-08-21 11:10:44 UTC - Size: 83.86 KB - 227 views
[2025-08-21 15:32:36]
1. Refer to the following:
Help With Daily Profit/Loss Value
2. This is relatively common with Interactive Brokers. Refer to the following:
Interactive Brokers Trading Service: Trade Position Line or Quantity Disappearing or Displaying Zero
