Date/Time: Wed, 25 Nov 2026 16:02:58 +0000
Trendline
View Count: 466
[2025-08-21 01:42:54]
User357195 - Posts: 204
SC,
Is there a way to set a toggle to freeze a trendline tool in its place so that if I accidently click on it, it will not try to move with my cursor? Instead, it will just ignore that click and not highlight the trendline again unless I have toggled the freeze back to the off position. Also, having the ability to set this function globally as well as on each individual chart in a chartbook, would be the optimum.
Sierra Charts are the best, in my opinion.
[2025-08-21 15:13:15]
Refer to the following:
Chart Drawing Tools: Locking Chart Drawings
Note that you can lock/unlock multiple drawings at one time in the Manage Chart Drawings window.
