Date/Time: Wed, 25 Nov 2026 16:03:04 +0000
Chart lag
View Count: 582
| [2025-08-20 20:35:02] |
| User996503 - Posts: 17 |
When I have a plain vanilla chart open it seems to be staying as same price as my DOM but any other chart with a study on it or anything it has a small 2 second lag. Was not an issue before. Have tried every solution provided but nothing seems to work.
| [2025-08-20 20:48:39] |
Are you saying that you see a difference in the price between a chart and a Trading DOM? If so, then we would need to see an image of both items so we can see how they are different.
| [2025-08-26 12:56:13] |
I have attached a recording. Very left side of screen is chart with studies on it, the middle chart is the plain chart. As you can see the price lags behind by a little on the far left chart and the plain chart stays synced with the DOM.
| Attachment Deleted. Private File |
| [2025-08-27 16:40:40] |
| Sierra_Chart Engineering - Posts: 25481 |
Check the Chart Update Interval of that chart: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) Also try using Sierra Chart timers instead of operating system timers: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.58 - Using Sierra Chart Timers for Faster Updates Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
