Date/Time: Wed, 25 Nov 2026 20:52:01 +0000
Combining Ticks, Bid / Ask Market Order Column
View Count: 827
[2025-08-20 13:49:56]
USERlevels777 - Posts: 11
Is there a way combine ticks on the dom into one whole number like lets say instead of each tick of 23,400.00, 23,400.25, 23,400.50, 23,400.75 each individualized can I have the dom take the sum of all three on the bid and display that amount on the dom for bids? In addition is there a way in sierra charts to view bid and ask market orders column in the center of the DOM?
[2025-08-20 14:46:35]
John - SC Support - Posts: 48658
Refer to the following settings:
Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu)
Chart Settings: Apply Combine Increment in Ticks to Other Market Data Columns (Chart >> Chart Settings >> Market Depth menu)
The order of the columns is controlled through the "Customize Chart/Trade DOM Columns" window. Refer to the following and the item below it:
Global Trade Settings Windows: Move Up/Left (Trade >> Customize Chart/Trade DOM Columns)
[2025-09-22 14:23:56]
Hello, I paid for real time data and it says real time data is on but it is not real time as I compare to my other data suppliers, whats going on? Ive tried logging out and logging in, in addition to other reset methods already..
[2025-09-22 16:49:46]
Everything on your account looks good, so you should be getting real-time data for products traded on the CME exchange of the CME Group, as you have the "CME With Market Depth for Non-Professional Trading Accounts".
If you are having a problem with a CME exchange symbol, then please get us your Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
Date Time Of Last Edit: 2025-09-22 16:49:59
[2025-11-04 15:07:37]
Your systems real time data for nq seems to lag, ive tried to do multimple different things to get it to real time, what is the problem?
[2025-11-04 17:25:44]
What exactly are you seeing that makes you state this?
If you do not already have it displayed, be sure the "Data Delay" is added to the "Chart Header" and is in a position where you can see it on the chart. Refer to the following:
Global Settings Menu: Customize Chart Header - Standard (Global Settings menu)
We need to know what kind of values you are seeing in that entry, which will be precded by "DD:" in the header.
