Date/Time: Fri, 03 May 2024 07:01:44 +0000
[User Discussion] - Volume Study Possible?
View Count: 1839
[2014-10-09 06:40:49] |
drywater0 - Posts: 85 |
SC Support, Is there a study (or combination of studies) that would allow me to compare cumulative volume during the day to the corresponding average over previous days. Here is an example of what I'm trying to do. Assume the market opens at 9:30am and now it is 11:00am. I would like to compare the volume traded today versus the average volume traded over the last 10 days during the same 1.5 hour period from 9:30am to 11:00am. Appreciate your help. |
[2014-10-09 15:16:43] |
User48557 - Posts: 138 |
I use a "TPO profile chart" found in studys, Then in your chart settings set the desired time and make sure "use night session" is not checked off. Then add "volume" also found in studys. |
[2014-10-09 22:42:18] |
USer48557, Thanks for your reply. I'm familiar with the feature that you mention, but I'm not sure how to use this to get an average volume for the first 30min, 60min, 90min, etc for the previous days 10 days. Can you provide some more details? Thanks |
[2014-10-09 23:15:41] |
ganz - Posts: 1048 |
drywater0 check this https://www.bigmiketrading.com/sierra-chart/27104-relative-volume-sierra-chart.html |
[2014-10-09 23:52:01] |
The approach that i mentioned is more visual. I suppose you can spreadsheet that information and get a daily calculation.
Capture average volume.PNG / V - Attached On 2014-10-09 23:48:29 UTC - Size: 74.71 KB - 382 views |
