Date/Time: Wed, 25 Nov 2026 16:03:10 +0000
Recent SC version update 2782
View Count: 560
[2025-08-18 21:35:31]
Makusan - Posts: 19
Subject updated from 'Account Usage Time Update' to 'Recent SC version update 2782'
I updated recently and the new update has changed many settings in SC, and both the Rithmic and Teton service information is no longer displaying. see attached. Also the display price associated with extending rectangles has enlarged and I can not seem to find where to make changes to the text type and size of text.
imageSC-Rithmic-CredentialsMissing-08-17-25.png / V - Attached On 2025-08-18 21:35:13 UTC - Size: 39.33 KB - 275 views
imageSC-Teton-Routing-info missing-08-17-25.png / V - Attached On 2025-08-18 21:35:25 UTC - Size: 32.68 KB - 230 views
[2025-08-18 21:56:00]
Sierra_Chart Engineering - Posts: 25481
How many installations of Sierra Chart are you aware of that you have on your computer?
The usual reason for this problem is explained here:
Missing Files After Upgrading Software
You have installed Sierra Chart into a different folder, or even a different drive than where you had Sierra Chart installed to before.
