Date/Time: Wed, 25 Nov 2026 16:03:02 +0000
Editing the Sierra4.config File
View Count: 640
| [2025-08-17 17:06:25] |
| User327465 - Posts: 23 |
Hello, I want to do some branding in Sierra. From what I've read, this is a tricky proposition, but I'd like to fool with it even if I can't get good results. I want to understand how brokers and some programmers apply branding. I've seen a chart with the broker's name on it. I found a way to alter it by using the "Stationary Text Properties" window, but the changes are not saved when you close the chartbook and restart. Any help appreciated. |
| [2025-08-17 18:22:31] |
| Sierra_Chart Engineering - Posts: 25481 |
That file cannot be edited. To do customization set this: General Settings Window: Custom Title Bar Name (Global Settings >> General Settings >> GUI >> Application GUI) And also refer to: Command Line Parameters Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
