Date/Time: Wed, 25 Nov 2026 16:14:58 +0000
Trade history
View Count: 395
| [2025-08-12 17:11:39] |
| User201886 - Posts: 8 |
Hi, I save my trade order fills as a txt file but when i go to open spreadsheet, i cant find any of my files, i change it to all files and those files are not there, in the other categories like txt files etc, there is ablosultely nothing. please help.
| [2025-08-12 20:19:52] |
| Sierra_Chart Engineering - Posts: 25481 |
Where are you saving the file? Not sure how we can help with this. Make sure there is no error message when saving the file. That would be displayed in the Message Log: Message Log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
