Date/Time: Sat, 04 May 2024 21:57:55 +0000
alarms
View Count: 917
[2014-10-08 14:30:46] |
saxo12 - Posts: 38 |
Hi Anyone know why after I draw a line/rectangle and set the alarm on the chart drawing properties the alarm doesnt go off Thanks |
[2014-10-08 17:01:18] |
There are many questions here. What are the Alert Settings for the Chart Drawing. Where is the chart drawing on the chart. What is the price of the last bar the chart. It really is a very hard question to answer because there are so many variables. The other question is whether you see an alert message in Window >> Show/Hide Alert Manager. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
