Date/Time: Wed, 25 Nov 2026 21:06:10 +0000
how save chart with copied drawings
View Count: 627
| [2025-08-12 14:54:56] |
| User12089 - Posts: 386 |
is there a way to save chart which contains copied drawings (e.g. lines) from another chart in way which would preserve the copied drawings until that point in time what i mean by that is when i open the such saved chartin e.g. another chartbook it would render the previously copied drawings withouyt any dependency on the chart which was the source of the drawings |
| [2025-08-14 03:49:13] |
| Sierra_Chart Engineering - Posts: 25483 |
You need to manually copy drawings from one chart to another one by one using the functionality described here: Chart Drawing Tools: Copy and Paste Chart Drawing Operations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-14 02:03:35] |
| ForgivingComputers.com - Posts: 1256 |
I have a tool that exports drawings to a CSV file for import to other charts. The files can be saved for later use. https://forgivingcomputers.com/product/fc-drawing-export-and-import-tools/ |
