Date/Time: Wed, 25 Nov 2026 16:14:53 +0000
[Programming Help] - Export Zones Study
View Count: 551
[2025-08-11 05:56:23]
Grev - Posts: 9
Is it possible to code a study to export zones or values drawn on a chart into a pinescript template?
[2025-08-11 10:38:29]
DFromeaux - Posts: 29
PineScript has no external input/output capabilities. It is completely closed and self-contained.
The simplest approach is to create a study in ACSIL for Sierra Chart that generates a large formatted text string containing all the zones. You can then either copy this text to the clipboard or export it to a .txt file.
Next, you would create a study in PineScript for TradingView that allows the user to paste the string into a user setting, then properly parse the string to retrieve the information and use it.
[2025-08-11 20:06:48]
Sierra_Chart Engineering - Posts: 25481
You can certainly export the chart bar and study data. Refer to:
Edit Menu: Edit >> Export Bar and Study Data to Text File
