Date/Time: Wed, 25 Nov 2026 16:14:57 +0000
DOM - Pull Stack Inaccurate
View Count: 1152
| [2025-08-08 14:15:42] |
| UTkRussell - Posts: 31 |
John, Are there any known bugs with regards to the DOM Pull Stack Columns? See attached photo. For reference, I'm using this on the /ES with the pull stack depth set to 20. Based on my calculations, it should be 744 on the Ask, 232 on the Bid, not in the thousands as shown. |
| [2025-08-08 16:39:55] |
There are no known issues with the calculation of the Pulling/Stacking totals. This is the first time we have seen something this odd. We really do not know how/why this is occurring. Please restart Sierra Chart and let us know if the issue resolves itself or not. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-08 17:49:12] |
Restarting SC appears to have fixed the issue. FYI, I first encountered this yesterday; I just assumed it was a fluke. On startup it looked fine, but at some point during the day (and I couldn't pin-point exactly what time) it started showing the insanely high values. I'll pay more attention next week and comment again if I see it. |
| [2025-08-08 19:17:37] |
Yes, please let us know right away if you see it.
| [2025-08-09 14:07:17] |
John, I was running a market replay on the data from yesterday (Friday) and may have found the issue. Chart Settings -> Market Depth -> Maximum Market Depth Pulling Stacking Levels = 20 However, under Chart DOM Settings - Global -> Other -> Max Bid/Ask Depth Pulling/Stacking Levels (0=All), I had this set to 0. Once I changed this setting to 20, I'm getting accurate text totals. In Summary, the individual 'chart settings' appears to be controlling the number of levels that I can visually see, but the 'global settings' appears to be doing the text total calculations. |
| [2025-08-11 14:05:56] |
| Sierra_Chart Engineering - Posts: 25481 |
Yes this makes sense.
